Intel X520-SR1 Bulk Ethernet Converged Network Adapter
Quicklinx: 8ZHJWS00 Mfr#: E10G41BFSRBLK
The Intel Ethernet 10 Gigabit Converged Network Adapter X520-SR1 enables data center transformation by delivering a reliable, unified 10GbE short range fiber optic connection. The Intel Ethernet Converged Network Adapter X520 provides advanced unified networking capabilities, including support for iSCSI, NFS, and FCoE. The Intel Ethernet Converged Network Adapter X520 facilitates greater network infrastructure consolidation and is the best choice for I/O virtualization. Intel Ethernet - it just works!
  • Efficient cooling
    Designed to operate within a wide temperature range, the Intel Ethernet Converged Network Adapter X520-SR1 ensures reliable performance from 0°C to 55°C. This feature ensures stable operation in various environmental conditions, making it suitable for data centers and high-temperature environments.
  • High-speed connectivity
    With a data transfer rate of 10 Gbps and support for Ethernet 10GBase-SR, the adapter provides high-speed connectivity for demanding network applications. It's ideal for high-performance computing, data analytics, and server virtualization.
  • Advanced networking features
    Supporting a range of networking protocols including IEEE standards, VLAN, and Virtual Machine Device Queues (VMDq), the adapter enhances data flow efficiency and security. It's designed to improve network management and support features like Fiber Channel over Ethernet (FCoE).
  • Secure and compliant
    Meeting multiple compliance standards such as FCC, RoHS, and UL, the Intel Ethernet Converged Network Adapter X520-SR1 adheres to strict regulatory requirements. This ensures a high level of reliability and safety for users.
  • Versatile compatibility
    The adapter's compatibility with PCI Express 2.0 x8 slots and its low-profile form factor make it a versatile solution for a wide range of PC systems. This flexibility allows for easy integration into existing setups without the need for extensive modifications.
Intel Ethernet Converged Network Adapter X520-SR1 - network adapter - PCIe 2.0 x8 - 10GBase-SR
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x8
Ports
10GBase-SR
Cabling Type
Ethernet 10GBase-SR
1GbE, 10GbE, FCoE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP, IPSec, iSCSI
Intel 82599ES
IEEE 802.3, IEEE 802.1Q, IEEE 802.3ad (LACP), IEEE 802.1ae, IEEE 802.1as
Microsoft Windows 7, Linux 2.6.x, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 SP2, Microsoft Windows Vista SP2, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2003 SP2, Red Hat Enterprise Linux 6, VMware ESXi, Windows 8, Microsoft Windows Server 2012, VMware ESX, Linux 3.x, FreeBSD 9
Network adapter
PCI Express 2.0 x8
Ports
10GBase-SR
Wired
Cabling Type
Ethernet 10GBase-SR
Gigabit Ethernet, 10 Gigabit Ethernet, Fibre Channel over Ethernet (FCoE)
Data Transfer Rate
10 Gbps
Remote Management Protocol
SNMP, RMON
Status Indicators
Port transmission speed, link/activity
Load balancing, VLAN support, VMDq
Processor / Memory
Intel 82599ES
1 x 10GBASE-SR - LC multi-mode - x 2
Compatible Slots
1 x PCI Express 2.0 x8
FCC Class B certified, UL, VCCI, C-Tick, BSMI, RoHS
Package Type
Bulk
Limited warranty - lifetime
55 °C
8ZHJ Intel Ethernet SFP+ Optics – SR In Stock £23.80
