Intel X520-DA2 Bulk Ethernet Converged Network Adapter
Quicklinx: 8ZHCWS00 Mfr#: E10G42BTDABLK
Intel's family of adapter, the Intel' Ethernet Converged Network Adapter X520 with SFP+ connectivity, is the flexible and scalable Ethernet adapter for today's demanding data center environments. Data center networks are being pushed to their limits. The escalating deployments of servers with multi-core processors and demanding applications such as High Performance Computing (HPC), database clusters, and video-on-demand are driving the need for 10 Gbps connections. Customers require flexible and scalable I/O solutions to meet the rigorous requirements of running mission-critical applications in virtualized and unified storage environments.
  • Low-profile
    Enables higher bandwidth and throughput from standard and low-profile PCIe slots and servers.
  • Load balancing on multiple CPUs
    Increases performance on multi-processor systems by efficiently balance CPU cores when used with Receive-Side Scaling (RSS) from Microsoft or scalable I/O on Linux.
  • ISCSI remote boot support
    Provides centralized storage area network (SAN) management at a lower cost than other iSCSI solutions.
  • Intel Direct Cache Access (DCA)
    Enables the adapter to pre-fetch the data from memory, avoiding cache misses and improving application response time.
  • MSI-X support
    Minimizes the overhead of interrupts. Load-balancing of interrupt handling between multiple cores/CPUs.
  • Low latency interrupts
    Based on the sensitivity of the incoming data, the adapter can bypass the automatic moderation of time intervals between the interrupts.
  • Header splits and replication in receive
    Helps the driver focus on the relevant part of the packet without the need to parse it.
  • IPsec offload
    Offloads IPsec capability onto the adapter instead of the software to significantly improve I/O throughput and CPU usage.
  • Virtual Machine Load Balancing (VLMB)
    Virtual Machines Load Balancing (VMLB) provides traffic load balancing across virtual switch, port, cable, or adapter failure.
  • Watchdog timer
    Gives an indication to the manageability firmware or external devices that the chip or the driver is not functioning.
Intel Ethernet Converged Network Adapter X520-DA2 - network adapter - PCIe 2.0 x8 - 10Gb Ethernet x 2
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x8
Ports
10Gb Ethernet x 2
10GbE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP, IPSec, iSCSI
Intel 82599ES
IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1ae, IEEE 802.1as
Microsoft Windows 7, Linux 2.6.x, SuSE Linux Enterprise Server 11, Microsoft Windows Server 2008 SP2, Microsoft Windows Vista SP2, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2003 R2, Red Hat Enterprise Linux 5, Microsoft Windows Server 2003 SP2, Red Hat Enterprise Linux 6, VMware ESXi, Windows 8, Microsoft Windows Server 2012, VMware ESX, Linux 3.x, FreeBSD 9
Network adapter
PCI Express 2.0 x8
Ports
10Gb Ethernet x 2
Wired
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
Remote Management Protocol
SNMP, RMON
Status Indicators
Port transmission speed, link/activity
Load balancing, VLAN support, VMDq
Processor / Memory
Intel 82599ES
2 x 10Gb Ethernet - SFP+ - x 2
Compatible Slots
1 x PCI Express 2.0 x8
FCC Class B certified, UL, VCCI, C-Tick, BSMI, RoHS
Package Type
Bulk
Limited warranty - lifetime
55 °C
8ZHC Intel Ethernet SFP+ Optics – SR In Stock £24.98
