The Intel SSD DC P3600 Series is a PCIe Gen3 SSD architected with the high performance controller interface, Non-Volatile Memory Express (NVMe), delivering leading performance, low latency, and quality of service.
With PCIe Gen3 support and NVMe queuing interface, the Intel SSD DC P3600 Series delivers excellent sequential read performance of up to 2.8 GB/s and sequential write speeds of up to 1700 MB/s. Intel SSD DC P3600 Series delivers very high random read IOPS of 450K and random write IOPS of 70K for 4 KB operations. Taking advantage of the direct path from the storage to the CPU by means of NVMe, Intel SSD DC P3600 Series exhibits low latency of less than 20 µs for sequential access to the SSD.
- Intel Solid-State Drive DC P3600 Series - solid state drive - 800 GB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 800 GB
- NAND Flash Memory Type
- 20nm multi-level cell (MLC)
- Interface
- Temperature sensor, End-to-end data protection (ANSI), High Endurance Technology (HET), S.M.A.R.T.
- 1.874 cm x 16.765 cm x 6.89 cm
- 185 g
- Microsoft Certification
- Compatible with Windows 7
- Capacity
- 800 GB
- Interface
- 1.874 cm
- 16.765 cm
- 6.89 cm
- 185 g
Performance
- Internal Data Rate
- 2600 MBps (read) / 1000 MBps (write)
- 4KB Random Read
- 430000 IOPS
- 4KB Random Write
- 50000 IOPS
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
- Power Consumption
- 12 Watt (write) , 9 Watt (read) , 4 Watt (idle)
- OS Required
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Red Hat Enterprise Linux 6.5
- UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, WHQL, FCC Part 15 B, RoHS, KCC, IEC 60950-1 Second Edition, CEM
- 0 °C
- 55 °C
- 5 - 95%
