Intel SSD Data Center P3600 Series 400GB 2.5" PCIe 3.0 20nm MLC
Quicklinx: 9JTTWS00 Mfr#: SSDPE2ME400G401
The Intel SSD DC P3600 Series is a PCIe Gen3 SSD architected with the high performance controller interface, Non-Volatile Memory Express (NVMe), delivering leading performance, low latency, and quality of service. Matching the performance with stunning reliability and endurance, Intel SSD DC P3600 Series offers great capacity.
With PCIe Gen3 support and NVMe queuing interface, the Intel SSD DC P3600 Series delivers excellent sequential read performance and sequential write speeds. Intel SSD DC P3600 Series delivers very high random read IOPS of 450 K and random write IOPS of 70 K for 4 KB operations. Taking advantage of the direct path from the storage to the CPU by means of NVMe, Intel SSD DC P3600 Series exhibits low latency of less than 20 µs for sequential access to the SSD.
  • Enhanced durability
    Equipped with High Endurance Technology (HET) and end-to-end data protection, this solid-state drive offers reliable storage with a significantly reduced risk of data loss, ensuring your information remains safe even under demanding conditions.
  • Optimized performance
    Featuring an impressive internal data rate of up to 2.1 GBps for reading and 550 MBps for writing, alongside 4KB random read of 320,000 IOPS and 4KB random write of 30,000 IOPS, this drive delivers swift and efficient performance for all your computing needs.
  • High compatibility
    Designed to be compatible with PC and certified by a wide range of compliance standards including RoHS, UL, and FCC Part 15 B, this drive ensures a broad compatibility with various systems and adherence to global regulations.
  • Efficient power management
    With power consumption modes optimized for write (8 W), read (7 W), and idle (4 W), it balances performance with energy efficiency, reducing operational costs and extending battery life in portable devices.
Intel Solid-State Drive DC P3600 Series - SSD - 400 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
400 GB
NAND Flash Memory Type
20nm multi-level cell (MLC)
2.5"
PCIe 3.0 x4 (NVMe)
Temperature sensor, End-to-end data protection (ANSI), High Endurance Technology (HET), S.M.A.R.T.
6.985 cm x 10.045 cm x 1.5 cm
115 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
400 GB
2.5"
PCIe 3.0 x4 (NVMe)
6.985 cm
10.045 cm
1.5 cm
115 g
Performance
Internal Data Rate
2.1 GBps (read) / 550 MBps (write)
4KB Random Read
320000 IOPS
4KB Random Write
30000 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
Compatible Bay
2.5"
Power Consumption
8 watt (write) , 7 watt (read) , 4 watt (idle)
Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Red Hat Enterprise Linux 6.5
UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, WHQL, FCC Part 15 B, RoHS, KCC, IEC 60950-1 Second Edition, CEM
Limited warranty - 5 years
55 °C
5 - 95%
