The Intel SSD DC P3600 Series is a PCIe Gen3 SSD architected with the high performance controller interface, Non-Volatile Memory Express (NVMe), delivering leading performance, low latency, and quality of service. Matching the performance with stunning reliability and endurance, Intel SSD DC P3600 Series offers great capacity.
With PCIe Gen3 support and NVMe queuing interface, the Intel SSD DC P3600 Series delivers excellent sequential read performance and sequential write speeds. Intel SSD DC P3600 Series delivers very high random read IOPS of 450 K and random write IOPS of 70 K for 4 KB operations. Taking advantage of the direct path from the storage to the CPU by means of NVMe, Intel SSD DC P3600 Series exhibits low latency of less than 20 µs for sequential access to the SSD.
Enhanced durability
Equipped with High Endurance Technology (HET) and end-to-end data protection, this solid-state drive offers reliable durability and security for your data, ensuring peace of mind with every use. -
Optimized performance
Featuring an impressive 4KB random read of 450,000 IOPS and a write of 50,000 IOPS, coupled with an internal data rate of 2600 MBps (read) and 1250 MBps (write), this drive delivers high-speed performance for demanding applications. -
Efficient operation
With power consumption modes optimized for write (15 watts), read (9 watts), and idle (4 watts), it balances performance and efficiency, making it an ideal choice for energy-conscious setups.
- Intel Solid-State Drive DC P3600 Series - SSD - 1.2 TB - PCIe 3.0 x4 (NVMe)
- Solid state drive - internal
- Capacity
- 1.2 TB
- NAND Flash Memory Type
- 20nm multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- Temperature sensor, End-to-end data protection (ANSI), High Endurance Technology (HET), S.M.A.R.T.
- 6.985 cm x 10.045 cm x 1.5 cm
- 125 g
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 1.2 TB
- Form Factor
- 2.5"
- Interface
- 6.985 cm
- 10.045 cm
- 1.5 cm
- 125 g
Performance
- Internal Data Rate
- 2600 MBps (read) / 1250 MBps (write)
- 4KB Random Read
- 450000 IOPS
- 4KB Random Write
- 50000 IOPS
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- Compatible Bay
- 2.5"
- Power Consumption
- 15 Watt (write) , 9 Watt (read) , 4 Watt (idle)
- OS Required
- Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Red Hat Enterprise Linux 6.5
- UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, WHQL, FCC Part 15 B, RoHS, KCC, IEC 60950-1 Second Edition, CEM
- Limited warranty - 5 years
- 0 °C
- 55 °C
- 5 - 95%
