Intel SSD Data Center P3600 Series 1.2TB 1/2 Height PCIe 3.0 20nm MLC
Quicklinx: 9JTJWS00 Mfr#: SSDPEDME012T401
The Intel SSD DC P3600 Series is a PCIe Gen3 SSD architected with the high performance controller interface, Non-Volatile Memory Express (NVMe), delivering leading performance, low latency, and quality of service. Matching the performance with world-class reliability and endurance, Intel SSD DC P3600 Series offers a range of capacity - 1.2 TB in both add-in card and 2.5-inch form factor.
With PCIe Gen3 support and NVMe queuing interface, the Intel SSD DC P3600 Series delivers excellent sequential read performance of up to 2.8 GB/s and sequential write speeds of up to 1700 MB/s. Intel SSD DC P3600 Series delivers very high random read IOPS of 450 K and random write IOPS of 70 K for 4 KB operations. Taking advantage of the direct path from the storage to the CPU by means of NVMe, Intel SSD DC P3600 Series exhibits low latency of less than 20 µs for sequential access to the SSD.
The 2.5-inch Intel SSD DC P3600 Series takes advantage of the 8639 connector and provides hot-pluggable removal and insertion providing in-service replacement options.
  • Enhanced durability
    Equipped with High Endurance Technology (HET) and end-to-end data protection, this solid-state drive ensures your data remains safe and secure, even under intense workloads.
  • Exceptional performance
    Boasting an impressive internal data rate of 2600 MBps for reading and 1250 MBps for writing, alongside 4KB random read of 450,000 IOPS and 4KB random write of 50,000 IOPS, this drive delivers swift and reliable performance for demanding applications.
  • Efficient power consumption
    Optimized for efficiency, the drive consumes only 15 W during write operations, 9 W during read operations, and a mere 4 W in idle mode, making it an energy-efficient choice for your computing needs.
  • Broad compatibility
    Designed to be compatible with PC and certified by Microsoft for Windows 7, this drive offers wide-ranging support for various computing environments.
  • Robust reliability
    With a mean time between failures (MTBF) of 2,000,000 hours and compliance with multiple standards including RoHS, UL, and FCC Part 15 B, this solid-state drive is built to last and meet rigorous regulatory standards.
Intel Solid-State Drive DC P3600 Series - SSD - 1.2 TB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
1.2 TB
NAND Flash Memory Type
20nm multi-level cell (MLC)
PCIe 3.0 x4 (NVMe)
Temperature sensor, End-to-end data protection (ANSI), High Endurance Technology (HET), S.M.A.R.T.
1.874 cm x 16.765 cm x 6.89 cm
195 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
1.2 TB
PCIe 3.0 x4 (NVMe)
1.874 cm
16.765 cm
6.89 cm
195 g
Performance
Internal Data Rate
2600 MBps (read) / 1250 MBps (write)
4KB Random Read
450000 IOPS
4KB Random Write
50000 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Power Consumption
15 Watt (write) , 9 Watt (read) , 4 Watt (idle)
Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Red Hat Enterprise Linux 6.5
UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, WHQL, FCC Part 15 B, RoHS, KCC, IEC 60950-1 Second Edition, CEM
Limited warranty - 5 years
55 °C
5 - 95%
