The Intel RAID Smart Battery (RSB) is a small battery pack accessory to the Intel Integrated Server RAID and the SCSI RAID on Motherboard (ROMB) solutions used on particular Intel Server Platforms. The Smart Battery preserves the contents of the RAID DIMM in the event of a power failure. Once power is restored, all of the preserved data in the RAID Cache DIMM is flushed to the RAID drives. The Smart Battery Circuit ensures that the backup battery is maintained at a full charge for optimal performance when it is activated. When activated, it provides backup power to the RAID DIMM for up to 64 hours.
- Intel RAID Smart Battery - memory backup battery - NiMH - 880 mAh
- Memory backup battery
- 95 g
- Battery
- Nickel Metal Hydride - 880 mAh
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Run Time (Up To)
- 72 hours
- 9.4 cm x 5.6 cm
- 1-year warranty
- Battery Enclosure Type
- Internal
- Quantity
- 1
- Technology
- Voltage Provided
- 4.8 V
- Capacity
- 880 mAh
- Run Time (Up To)
- 72 hrs
- Recharge Time
- 8 hours
- Max Recharge Cycles
- 500
- MTBF
- 2,471,650 hours
- Limited warranty - 1 year
- 10 °C
- 40 °C
- 20 - 80%
- 9.4 cm
- 5.6 cm
- 95 g
