Intel PRO/1000GT QUAD SERVER PORT
Quicklinx: 4FV7WS00 Mfr#: PWLA8494GT
Access multiple network segments, conserve valuable Peripheral Component Interconnect (PCI) slots in servers, and migrate existing Category-5 (CAT-5) networks to Gigabit Ethernet easily and cost-effectively with the Intel PRO/1000 GT Quad Port Server Adapter. Standards-based management features help ensure compatibility with the latest server and networking environments. Enhance server performance further by teaming connections on this adapter with each other, with connections on other Intel PRO Server Adapters or with LAN-on-motherboard components using the Intel advanced server features to achieve multi-Gigabit scalability and redundant failover capability.
Intel PRO/1000 GT Quad Port Server Adapter - It just works!
Intel PRO/1000 GT Quad Port Server Adapter - network adapter - PCI-X - Gigabit Ethernet x 4
Network adapter
Plug-in card
Interface (Bus) Type
PCI-X / 133 MHz
Ports
16.5 cm x 10.7 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
2 x Intel 82546GB
RAM
256 KB
IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP)
Novell NetWare 5.1, UnixWare 7 or later, Caldera OpenUnix 8, Linux 2.4 or later, Novell NetWare 6, FreeBSD 4.0 or later, Microsoft Windows 2000 / XP, SunSoft Solaris 7/8, Microsoft Windows Server 2003, Novell NetWare 6.5
Microsoft Certification
Works with Windows Vista
Network adapter
Plug-in card
PCI-X / 133 MHz
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Remote Management Protocol
SNMP, DMI
Auto-sensing per device, WOL
Processor / Memory
2 x Intel 82546GB
RAM
256 KB
4 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI-X / 133 MHz - full-height
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
ACPI, FCC Class B certified, VCCI, BSMI, GOST, ICES-003, AS/NZS 3548
16.5 cm
10.7 cm
Limited warranty - lifetime
55 °C
0 - 85%
