Now you can maximize system performance and increase end-user productivity for mainstream PCs with the Intel PRO/1000 GT Desktop Adapter. Today's desktops are weighed down with high-bandwidth applications including voice, data, streaming video, video conferencing, and long-distance storage area networks. The environmentally friendly Intel PRO/1000 GT Desktop Adapter's Gigabit bandwidth makes quick work of these network applications with power to spare. Built on Intel lead-free technology, the Intel PRO/1000 GT Desktop Adapter is the environmentally friendly way to bring Gigabit performance to your desktop.
Simplify installation and maintenance with Intel Single Driver technology
Intel offers a single driver across all Intel PRO/1000 Desktop and Server Adapters making it easier to administer and upgrade to the latest generation of Intel adapters, simplifying network management and reducing maintenance costs. -
High-performing, auto-negotiating 10/100/1000 connection
Systems that are currently running at 10 Mbps or 100 Mbps can be upgraded with the Intel PRO/1000 GT Desktop Adapter now, whether Gigabit switching is currently available or not. By integrating an Intel PRO Gigabit Network Connection now, information technology (IT) managers will save time, money and downtime when the network is upgraded later because the Intel PRO/1000 GT Desktop Adapter will automatically detect and run at the higher speed when it becomes available.
- Intel PRO/1000 GT Desktop Adapter - network adapter - PCI / 66 MHz - Gigabit Ethernet
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI / 66 MHz
- PCI Specification Revision
- PCI 2.3
- Bus Voltage
- 5.0 V
- Ports
- Gigabit Ethernet
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- TCP/IP
- Processor
- 1 x Intel 82541PI
- RAM
- 64 KB
- IEEE 802.2, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, WfM 2.0
- System Requirements
- Microsoft DOS, Novell NetWare 4.2, Novell NetWare 5.1, Microsoft Windows 2000 / NT4.0, Linux 2.2.5 or later, Microsoft Windows XP, Microsoft Windows 98 Second Edition / Windows ME, Novell NetWare 6
- Microsoft Certification
- Certified for Windows Vista
- Limited lifetime warranty
- Network adapter
- Form Factor
- Plug-in card
- PCI / 66 MHz
- PCI 2.3
- Bus Voltage
- 5.0 V
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- TCP/IP
- Remote Management Protocol
- SNMP, DMI 2.0
- Flow control, full duplex capability, ACPI support, auto-negotiation, VLAN support, WOL, manageable
Processor / Memory
- Processor
- 1 x Intel 82541PI
- RAM
- 64 KB
- 1 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x PCI / 66 MHz
- Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
- Plug and Play, ACPI, FCC Class B certified, VCCI Class B ITE, BSMI CNS 13438 Class B, Lead-Free
- Package Type
- Bulk
- Software Included
- Drivers & Utilities, Intel PROSet
- OS Required
- Limited warranty - lifetime
- 0 °C
- 55 °C
- 0 - 85%
