Intel PRO/1000 PT Dual Port Server Adapter - Network adapter - PCI Express
Quicklinx: 4MZQWS00 Mfr#: EXPI9402PT
Conserve valuable PCI Express (PCIe) server slots while adding multi-port Gigabit Ethernet capability with the Intel PRO/1000 PT Dual Port Server Adapter. The dedicated input/output (I/O) bandwidth of PCIe ensures priority performance on each port - without bus sharing - for Gigabit Ethernet connectivity in Category-5 networks. Additionally, the Intel PRO/1000 PT Dual Port Server Adapter is designed to provide high performance in multi-processor systems by efficiently balancing network loads across multiple Central Processing Units (CPUs) when used with Receive-Side Scaling from Microsoft or Scalable I/O on Linux.
Intel PRO/1000 PT Dual Port Server Adapter - It just works!
Intel PRO/1000 PT Dual Port Server Adapter - network adapter - PCIe x4 - Gigabit Ethernet x 2
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
PCI Specification Revision
PCIe 1.0a
Ports
2.2 cm x 12.9 cm x 12 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
1 x Intel 82571EB
IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), WfM 2.0
SCO OpenServer 5, Microsoft Windows 2000, Novell NetWare 5.x, SunSoft Solaris x86 8, Novell NetWare 6.x, Caldera OpenUnix 8, Linux 2.4 or later, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Datacenter Edition, FreeBSD 4.x
Microsoft Certification
Compatible with Windows 7
Network adapter
Plug-in card
PCI Express x4
PCIe 1.0a
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
Remote Management Protocol
SNMP, DMI 2.0
Status Indicators
Port transmission speed, link OK
Full duplex capability, ACPI support, auto-negotiation, WOL, Intel I/OAT
Processor / Memory
1 x Intel 82571EB
2 x 1000Base-T - RJ-45
Compatible Slots
1 x PCI Express x4
FCC Class B certified, UL, VCCI, C-Tick, BSMI, MIC
Software Included
Intel PROSet
2.2 cm
12.9 cm
12 cm
Limited warranty - lifetime
55 °C
