Intel PRO/1000 PF Server Adapter - Network adapter - PCI Express
Quicklinx: 4MZTWS00 Mfr#: EXPI9400PFBLK
The Intel PRO/1000 PF Server Adapter represents the fifth generation of Intel network adapters for Gigabit Ethernet, and features 10/100/1000 Mbps self-configuration for compatibility with mixed speed network devices. For easy installation and management, all Intel PRO Network Connections are supported by Intel PRO Intelligent Install and the new Intel PROSet Utility for Microsoft Device Manager. Intel PROSet simplifies adapter installation and gives you point-and-click power to configure and manage all your Intel PRO Network Connections for connectivity you can count on. Take advantage of PCI Express (PCIe) server slots to enhance network performance with the Intel PRO/1000 PF Server Adapter. The dedicated input/output (I/O) bandwidth of PCIe ensures priority performance - without bus sharing - for Gigabit Ethernet connectivity in Category-5 networks.
Intel Ethernet - It Just Works!
Intel PRO/1000 PF Server Adapter - network adapter - PCIe x4 - 1000Base-SX
Network adapter
Plug-in card
Interface (Bus) Type
PCI Express x4
PCI Specification Revision
PCIe 1.0a
Ports
1000Base-SX
2.2 cm x 13 cm x 12 cm
Cabling Type
Ethernet 1000Base-SX
1GbE
Max Transfer Distance
550 m
Data Transfer Rate
1 Gbps
Intel 82572EI
IEEE 802.3u, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), WfM 2.0
SCO OpenServer 5, Microsoft Windows 2000, Novell NetWare 5.x, SunSoft Solaris x86 8, Novell NetWare 6.x, Caldera OpenUnix 8, Linux 2.4 or later, Microsoft Windows Server 2003 Enterprise Edition, Microsoft Windows Server 2003 Datacenter Edition, FreeBSD 4.x
Microsoft Certification
Compatible with Windows 7
Network adapter
Plug-in card
PCI Express x4
PCIe 1.0a
Ports
1000Base-SX
Wired
Cabling Type
Gigabit Ethernet
Data Transfer Rate
1 Gbps
550 m
Remote Management Protocol
SNMP, DMI 2.0
Status Indicators
Port transmission speed, link OK
Flow control, full duplex capability, ACPI support, auto-negotiation, load balancing, VLAN support, WOL, Intel I/OAT
Processor / Memory
Intel 82572EI
1 x 1000Base-SX - LC multi-mode - x 2
Compatible Slots
1 x PCI Express x4
FCC Class B certified, UL, VCCI, C-Tick, BSMI, MIC
Software Included
Intel PROSet
2.2 cm
13 cm
12 cm
Limited warranty - lifetime
55 °C
