Intel P4800X 375GB HHHL AIC NVMe SSD
Quicklinx: DCGQWS00 Mfr#: SSDPED1K375GA01
Delivering amazing combination of low latency, ultra endurance, high QoS, and high throughput, the Intel Optane DC P4800X series is the extremely responsive data center hard drive. Built with the excellent memory media, the DC P4800X is the product to combine the attributes of memory and storage. This innovative solution is optimized to break through storage bottlenecks by providing an improved data tier. It accelerates applications for fast caching and storage, increases scale per server, and reduces transaction costs for latency sensitive workloads. In addition, data centers can now also deploy bigger and more affordable data sets to gain insights from large memory pools.
  • Robust durability
    Engineered to withstand the toughest conditions, this solid state drive boasts a shock acceleration (operating) of 50 g and a non-operating shock acceleration of the same magnitude, ensuring your data remains safe even in the most extreme scenarios.
  • Exceptional performance
    With an impressive 4KB random read of 550,000 IOPS and a 4KB random write of 500,000 IOPS, coupled with an average latency of just 10 µs, this SSD delivers speed and responsiveness for demanding enterprise workloads.
  • High capacity and endurance
    Offering a generous 375 GB capacity and an SSD endurance of 20.5 PB, this drive is not only capacious but also built to last, making it an ideal choice for intensive data storage and usage.
  • Advanced security
    Equipped with 256-bit AES hardware encryption, this SSD ensures your data is protected with a high level of security, safeguarding sensitive information against unauthorized access.
  • Energy efficient
    Designed with power efficiency in mind, this SSD consumes only 18 W during active use and a mere 5 W in idle mode, reducing operational costs and contributing to a greener environment.
Intel Optane SSD DC P4800X Series - SSD - 375 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
375 GB
SSD Technology
3D Xpoint (Optane)
Hardware Encryption
Encryption Algorithm
256-bit AES
PCIe card (HHHL)
PCIe 3.0 x4 (NVMe)
5-year warranty
375 GB
Hardware Encryption
256-bit AES
SSD Technology
3D Xpoint (Optane)
PCIe card (HHHL)
PCIe 3.0 x4 (NVMe)
Performance
SSD Endurance
20.5 PB
Internal Data Rate
2400 MBps (read) / 2000 MBps (write)
4KB Random Read
550000 IOPS
4KB Random Write
500000 IOPS
Average Latency
10 µs
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe)
Compatible Bay
PCIe card (HHHL)
Power Consumption
18 watt (active) , 5 watt (idle)
Limited warranty - 5 years
55 °C
Shock Tolerance (operating)
50 g
Shock Tolerance (non-operating)
50 g
Vibration Tolerance (operating)
2.17 g
Vibration Tolerance (non-operating)
3.13 g
