Intel P4501 4TB 2.5" U.2 NVMe SSD
Quicklinx: DCGKWS00 Mfr#: SSDPE7KX040T701
This cloud-inspired SSD is built with an entirely NVMe controller, optimized for read intensive workloads and created to maximize CPU utilization. Now you can store more and know more.
otimized for high performance-per-watt, power efficiency, and low power envelopes, this SSD enables opportunities to maximize storage capacity without incurring the power demands of larger, space-consuming form factors.
Intel Solid-State Drive DC P4501 Series - SSD - 4 TB - PCIe 3.1 x4 (NVMe)
Solid state drive - internal
4 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
PCIe 3.1 x4 (NVMe)
Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, End-to-end data protection
7 mm
5-year warranty
4 TB
Hardware Encryption
256-bit AES
2.5"
PCIe 3.1 x4 (NVMe)
7 mm
Performance
Internal Data Rate
3200 MBps (read) / 900 MBps (write)
4KB Random Read
361000 IOPS
4KB Random Write
46700 IOPS
Average Latency
30 µs
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x PCI Express 3.1 x4 (NVMe)
Compatible Bay
2.5"
Power Consumption
12.5 Watt (active) , 5 Watt (idle)
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1000 g @ 0.5 ms
Shock Tolerance (non-operating)
1000 g @ 0.5 ms
Vibration Tolerance (operating)
2.17 g
Vibration Tolerance (non-operating)
3.13 g
