Intel P4501 1TB 2.5" U.2 NVMe SSD
Quicklinx: DCGHWS00 Mfr#: SSDPE7KX010T701
This low power drive enables energy and space efficient storage solutions to help data centers do more per server minimize service disruptions and efficiently manage at scale. This cloud-inspired SSD is built with an entirely NVMe controller, optimized for read intensive workloads and created to maximize CPU utilization. Now you can store more and know more. Optimized for high performance-per-watt, power efficiency, and low power envelopes, this SSD enables opportunities to maximize storage capacity without incurring the power demands of larger, space-consuming form factors.
  • Power-efficient, high performance SSDs optimized for cloud storage
    This cloud-inspired SSD is built with an entirely NVMe controller, optimized for read intensive workloads and created to maximize CPU utilization. With the Intel SSD DC P4501 Series, data centers can increase users, add more services, and perform more workloads per server. Now you can store more and know more.
  • Optimized solutions for space and power efficiency
  • Outstanding quality and reliability
    With industry-leading quality and reliability, you can be confident your drives are available and your data is protected. Support for data-at-rest encryption minimizes the likelihood of data breaches, while industry-leading end-to-end data protection reduces the chance of silent data errors.
  • Advanced manageability and serviceability
    Built with advanced manageability features such as NVMe -MI, the Intel SSD DC P4501 Series allows you to remotely monitor, manage and remediate across more device states and streamline essential services.
Intel Solid-State Drive DC P4501 Series - SSD - 1 TB - PCIe 3.1 x4 (NVMe)
Solid state drive - internal
1 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
PCIe 3.1 x4 (NVMe)
Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, End-to-end data protection
7 mm
5-year warranty
1 TB
Hardware Encryption
256-bit AES
2.5"
PCIe 3.1 x4 (NVMe)
7 mm
Performance
Internal Data Rate
3200 MBps (read) / 650 MBps (write)
4KB Random Read
285000 IOPS
4KB Random Write
41000 IOPS
Average Latency
30 µs
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x PCI Express 3.1 x4 (NVMe)
Compatible Bay
2.5"
Power Consumption
12.5 watt (active) , 5 watt (idle)
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1000 g @ 0.5 ms
Shock Tolerance (non-operating)
1000 g @ 0.5 ms
Vibration Tolerance (operating)
2.17 g
Vibration Tolerance (non-operating)
3.13 g
