Intel P3100 360GB M.2 2280 NVMe SSD
Quicklinx: DCGZWS00 Mfr#: SSDPEKKA360G701
The Intel SSD DC P3100 Series delivers ideal endurance and performance for very read-intensive workloads in the data center. With the space-saving advantages delivered by the M.2 form factor and the drive's superior power efficiency, data centers can expect to see total cost of ownership benefits with the DC P3100.
  • Intel 3D NAND TLC technology
    The Intel Solid State Drive DC P3100 Series is Intel's 3D NAND TLC-based M.2 form factor SSD with the PCIe 3.0x4 and NVMe interface specifically architected for the data center.
  • Entry PCIe Boot Drive
    The Intel SSD DC P3100 Series delivers ideal endurance and performance for read-intensive workloads, and is specifically designed for data center usage models.
  • Single-sided for design flexibility
    All DC P3100 Series capacity points are single-sided M.2 form factor, giving data center designers the flexibility to implement higher-density storage solutions, or to allocate more space for other critical server components.
Intel Solid-State Drive DC P3100 Series - SSD - 360 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
360 GB
NAND Flash Memory Type
3D triple-level cell (TLC)
M.2 2280
PCIe 3.0 x4 (NVMe)
Read Unrecoverable Bit Error Rate (UBER) 10e-15, 256-bit AES
22 mm x 80 mm
10 g
5-year warranty
360 GB
M.2 2280
PCIe 3.0 x4 (NVMe)
22 mm
80 mm
10 g
Reliability
MTBF
1,600,000 hours
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe)
Compatible Bay
M.2 2280
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1000 g @ 0.5 ms
Shock Tolerance (non-operating)
1000 g @ 0.5 ms
Vibration Tolerance (operating)
2.17 g @ 5-700 Hz
Vibration Tolerance (non-operating)
3.13 g @ 5-800 Hz
