Intel NUC5i5RYK Core i5 5250U 1.6GHz LAN WLAN Bluetooth HD Graphics 6000
Quicklinx: B3ZKWS00 Mfr#: BOXNUC5i5RYK
  • Core i5
  • IEEE 802.11n
  • Bluetooth 4.0
A revolution in ultra-compact device design, the Intel NUC NUC5i5RYK packs more features into 4 inches square. The NUC5i5RYK is equipped with the 5th generation Intel Core i5-5250U processor with Intel Turbo Boost Technology 2.0 which gives you extra GHz on demand to let you maximize performance on processor-intensive tasks like media editing. A replaceable lid gives you plenty of options to create the NUC you want - with amazing style and features. It also features Intel HD Graphics 6000 with 4K display capabilities to provide visually stunning graphics. A high-speed USB 3.0 charging port lets you easily charge your tablet or smartphone quickly. Complete with WiFi 802.11ac wireless, Bluetooth, and 7.1 surround sound, the Intel NUC NUC5i5RYK is ideal for home theater PCs, media server PCs, and home hubs. For peace of mind, you'll get embedded security that helps keep threats out and user identities and credentials safe. With this kind of power, size, and versatility, you'll rethink what's possible.
  • Superior processing and graphics
    Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics.
  • Stunningly small form factor
    The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations.
  • Advanced technology
    The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
Intel Next Unit of Computing Kit NUC5i5RYK - mini PC Core i5 5250U 1.6 GHz - 0 GB - no HDD
PC barebone - mini PC - voltage monitoring, temperature sensor, Intel Rapid Start Technology, 1 USB 3.0 charging port, Intel Ready Mode Technology
1 x Intel Core i5 (5th Gen) 5250U / 1.6 GHz (up to 2.7 GHz, (Dual-Core)
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel 64 Technology
Cache Memory
3 MB
Cache Per Processor
3 MB
RAM
0 GB (installed) / 16 GB (max) - DDR3L SDRAM
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
Audio Output
7.1 channel surround - integrated
1GbE, 802.11a, 802.11b/g/n, Bluetooth 4.0, Wi-Fi 5
OS Provided
No operating system
Silver with black top and diamond cut around the top
11.5 cm x 11.1 cm x 3.45 cm
Limited warranty - replacement - 3 years
PC barebone
Product Form Factor
Mini PC
Built-in Devices
Infrared receiver
Processor / Chipset
CPU
Clock Speed
1.6 GHz
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
DDR3L SDRAM
SO-DIMM 204-pin
Slots
2 (Total) / 2 (empty)
Dual channel memory architecture
Hard Drive
No HDD
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Integrated
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 7265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
ACPI support, Intel Wireless Display (WiDi)
Slots
2 (total) / 2 (free) x SO-DIMM 204-pin ¦ 1 (total) / 1 (free) x M.2 Card
4 x USB 3.0 (2 front, 2 rear) , 1 x Mini-HDMI , 1 x Mini DisplayPort , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) - RJ-45 , 2 x SATA-600 (2 internal)
VESA mounting kit
Voltage monitoring, temperature sensor, Intel Rapid Start Technology, 1 USB 3.0 charging port, Intel Ready Mode Technology
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
EN55022, ICES-003, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI CNS 13438, ACPI 3.0b, VCCI V-3, Directive 2002/96/EC, VCCI V-4, KN22, KN24, China RoHS, Directive 2011/65/UE, CAN/CSA-C22.2 No. 60950-1
Power adapter
Power Provided
65 watt
Operating System / Software
OS Provided
No operating system
11.5 cm
11.1 cm
3.45 cm
50 °C
