No more compromising between performance, profile, and value. The NUC is a tiny computing device with the power of advanced processor. Its lower power consumption enables innovative system designs and energy-efficient applications in places like digital signage, home entertainment, and portable uses.
Superior processing and graphics
Visibly smart graphics using the advanced processor deliver amazing performance and visually stunning graphics. -
Stunningly small form factor
The compact form factor unlocks a world of potential design applications, from digital signage and kiosks to portable innovations. -
Advanced technology
The NUC features two sockets for expandability of memory, two mini-card connectors for flexible support of wireless and hard drive configurations, BIOS vault technology, fast boot and the Visual BIOS. The NUC also supports The Anti-Theft technology, providing hardware intelligence, designed to protect your device and its data, if its lost or stolen.
- Intel Next Unit of Computing Kit NUC7i3DNKE - mini PC - Core i3 7100U 2.4 GHz - 0 GB - no HDD
- PC barebone - mini PC
- Processor
- 1 x Intel Core i3 (7th Gen) 7100U / 2.4 GHz (Dual-Core)
- Processor Main Features
- Hyper-Threading Technology, Intel Execute Disable Bit, Enhanced Intel SpeedStep Technology, Intel Virtualization Technology, Intel 64 Technology, Intel AES New Instructions
- Cache Memory
- 3 MB
- Cache Per Processor
- 3 MB
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Graphics Controller
- Intel HD Graphics 620
- Audio Output
- 7.1 channel surround
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
- 11.5 cm x 11.1 cm x 3.6 cm
- Limited warranty - 3 years
- PC barebone
- Product Form Factor
- Mini PC
Processor / Chipset
- CPU
- Intel Core i3 (7th Gen) 7100U
- Clock Speed
- 2.4 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
Cache Memory
- Installed Size
- 3 MB
- 3 MB
RAM
- Installed Size
- 0 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Rated Memory Speed
- 2133 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI
Audio Output
- Sound Output Mode
- High Definition Audio
- Ethernet Controller
- Intel I219-V
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
- Bays
- 1 (total) / 1 (free) x internal M.2 2280 , 1 (total) / 0 (free) x internal M.2 2230
- Slots
- 2 (total) / 2 (free) x SO-DIMM 260-pin
- 4 x USB 3.0 - Type A (2 front, 2 rear) , 2 x USB 2.0 (2 internal) , 1 x USB 3.0 (1 internal) , 2 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x serial - DB-9
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Plug and Play, ICES-003, EN55024, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, FCC CFR47 Part 15 C, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-2, EN 62311, VCCI V-4, KN24, China RoHS, EN 300 328, CNS 13438, RoHS 2011/65/EU, WEEE 2012/19/EU, EN 301 489-1, EN 300 893, CISPR32/EN55032, KN32, AS/NZS 2772.2, FCC CFR47 Part 15 E, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- Power adapter
- Power Provided
- 65 Watt
- 11.5 cm
- 11.1 cm
- 3.6 cm
- 0 °C
- 40 °C
Intel NUC NUC7I3DNK3E Intel Core i3-7100U Dawson Canyon mini PC
