Get ready to be astonished by what small can do. A mini PC that performs like a desktop system, the Intel NUC Kit NUC6i3SYK is equipped with a great architecture. With 7.1 surround sound and a full-sized HDMI port for brilliant 4K resolution, NUC6i3SYK can power home entertainment and light gaming. All you need is 4 inches of space and you're able to stream beats, basketballs, and movies into your living room. You've got the performance you need to finish that last minute presentation or help your kid manage her homework. The consumer infrared sensor means you can control your NUC from the comfort of your couch.
Enjoy brilliant 4K displays with Intel HD Graphics
The Intel HD Graphics with 4K display capabilities provide a brilliant HD experience for gaming and home entertainment. You can watch theater-quality 4K videos in your living room, see photos the way they were meant to be seen, or grab a game controller and build your empire. -
Designed for you to get more done
With its high memory support, you can get the memory you need to multitask, and with 4 USB 3.0 ports including a USB charging port, you can use a USB keyboard, mouse, and printer, and still have room to charge your phone or tablet. -
Cut the cords, not the performance
The NUC6i3SYK features Intel Dual Band Wireless-AC 8260, so you can connect out of the box and access files, movies, and music in the cloud, along with built-in Bluetooth 4.1 so you can connect wireless peripherals. Playing content wirelessly from Intel NUC on your big-screen HDTV is easy with Intel Wireless Display (Intel WiDi). Watch videos. Display photos. Look at presentations. Connect your Intel NUC to a WiDi receiver or WiDi-enabled TV and experience rich, vibrant visuals and audio without the clutter of cables.
- Intel Next Unit of Computing Kit NUC6i3SYK - mini PC Core i3 6100U 2.3 GHz - 0 GB - no HDD
- PC barebone - mini PC
- Processor
- 1 x Intel Core i3 (6th Gen) 6100U / 2.3 GHz (Dual-Core)
- Cache Memory
- 3 MB L3 Cache
- Cache Per Processor
- 3 MB
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- Intel HD Graphics 520 - up to
- Audio Output
- 7.1 channel surround
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- Silver with black top and diamond cut around the top
- 11.5 cm x 11.1 cm x 3.2 cm
- Limited warranty - 3 years
- PC barebone
- Product Form Factor
- Mini PC
- Built-in Devices
- Infrared receiver
Processor / Chipset
- CPU
- Intel Core i3 (6th Gen) 6100U
- Clock Speed
- 2.3 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L3 Cache - 3 MB
- 3 MB
RAM
- Installed Size
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- 2 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SDXC UHS-I Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
Audio Output
- Sound Output Mode
- High Definition Audio
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Bays
- 1 (total) / 1 (free) x internal M.2 2242/2280
- Slots
- 2 (total) / 2 (free) x SO-DIMM 260-pin
- 4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 (2 internal) , 1 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x Mini DisplayPort , 2 x SATA-600 (2 internal)
- Included Accessories
- VESA mounting kit
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Plug and Play, ETSI, EN55022, ICES-003, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, WEEE, FCC CFR47 Part 15 B, VCCI V-3, EN 62311, VCCI V-4, Directive 2012/19/EU, Directive 2011/65/EU, KN22, KN24, EN 300.440, China RoHS, EN 300 328, CNS 13438, EN 301 489-1, FCC CFR47 Part 15 A, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- Power adapter
- Power Provided
- 65 Watt
- 11.5 cm
- 11.1 cm
- 3.2 cm
- 0 °C
- 50 °C
Intel Nuc Kit NUC6i3SYK Intel Core i3-6100U Barebone
