Intel NUC6i5SYK is equipped with advanced architecture and a powerful processor. High-performance graphics with 4K display capabilities provides brilliant resolution for gaming and home theaters. The thin NUC6i5SYK allows you to transfer your data at lightning speed. It has the performance to stream media, manage spreadsheets, or create presentations, all in a slim 4" x 4" form factor.
See your movies in brilliant graphics
Advanced graphics with amazing display capabilities provide a brilliant HD experience for gaming and home theaters. You can watch theater-quality videos in your living room or grab a game controller and answer the call of duty. You also have the performance you need to create content without having to wait as your video and images render. -
Amazing performance
The NUC6i5SYK has the performance you need to stream media, edit photos and files, or create projects. You can get the memory you need to multitask, and with 4 USB 3.0 ports including a USB charging port, you can use a USB keyboard, mouse, and a camera, and still have room to charge your phone or tablet. -
Excellent connectivity
Cut the cords, not the performance The NUC6i5SYK comes with the extremely fast wireless, so you can connect out of the box and access hies, movies, and music in the cloud, along with built-in Bluetooth 4.1. Watch videos, display photos, look at presentations. Connect your Intel NUC to a WiDi receiver or WiDi-enabled TV and experience rich, vibrant visuals and audio without the clutter of cables.
- Intel Next Unit of Computing Kit NUC6i5SYK - mini PC - Core i5 6260U 1.8 GHz - 0 GB - no HDD
- PC barebone - mini PC
- Processor
- 1 x Intel Core i5 (6th Gen) 6260U / 1.8 GHz (, up to 2.9 GHz, (Dual-Core)
- Processor Main Features
- Intel Virtualization Technology, Intel AES New Instructions
- Cache Memory
- 4 MB L3 Cache
- Cache Per Processor
- 4 MB
- RAM
- 0 GB (installed) / 32 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Card Reader
- Graphics Controller
- Intel Iris Graphics 540
- Audio Output
- 7.1 channel surround
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- Silver with black top and diamond cut around the top
- 11.5 cm x 11.1 cm x 3.2 cm
- Limited warranty - 3 years
- PC barebone
- Product Form Factor
- Mini PC
- Built-in Devices
- Infrared receiver
Processor / Chipset
- CPU
- Intel Core i5 (6th Gen) 6260U
- Clock Speed
- 1.8 GHz
- Max Turbo Speed
- 2.9 GHz
- Number of Cores
- Dual-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- L3 Cache - 4 MB
- 4 MB
RAM
- Installed Size
- 0 GB / 32 GB (max)
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Slots
- 2 (Total) / 2 (empty)
- Dual channel memory architecture
Hard Drive
- No HDD
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- No optical drive
Card Reader
- Card reader
- Supported Flash Memory Cards
- SDXC UHS-I Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI, DisplayPort
- Max Monitors Supported
- 3
Audio Output
- Sound Output Mode
- High Definition Audio
- Integrated
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8260
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Bays
- 1 (total) / 1 (free) x internal M.2 2242/2280
- Slots
- 2 (total) / 2 (free) x SO-DIMM 260-pin
- 4 x USB 3.0 (2 front, 2 rear) , 2 x USB 2.0 (2 internal) , 1 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x Mini DisplayPort , 2 x SATA-600 (2 internal)
- Included Accessories
- VESA mounting kit
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Plug and Play, ETSI, EN55022, ICES-003, EN55024, CISPR 22, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, WEEE, FCC CFR47 Part 15 B, VCCI V-3, EN 62311, VCCI V-4, Directive 2012/19/EU, Directive 2011/65/EU, KN22, KN24, EN 300.440, China RoHS, EN 300 328, CNS 13438, EN 301 489-1, FCC CFR47 Part 15 A, EN 301 893, CAN/CSA-C22.2 No. 60950-1, EN 301 489-17
- Power adapter
- Power Provided
- 65 Watt
- 11.5 cm
- 11.1 cm
- 3.2 cm
- 0 °C
- 50 °C
C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black | In Stock | £16.62 |
C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black | In Stock | £17.63 |
