Intel NUC Baby Canyon Core i3-7100U DDR4 M.2 PCIe USB3.1 Barebone
Quicklinx: CQ48WS00 Mfr#: BOXNUC7i3BNK
  • IEEE 802.11n
  • Core i3
The Intel NUC7i3BNK Mini PC NUC Kit sports a 2.7 GHz Intel Core i3-7100U dual-core processor as well as storage and memory slots, letting you build a compact system with the performance to handle entry-level applications. The NUC7i3BNK comes with two SODIMM slots that can hold up to 32GB of DDR4 2133 MHz memory chips. For internal storage, it is armed with an M.2 slot that can accept SATA- or PCIe-based SSDs with a length of up to 80mm. Once an optional M.2 SSD is mounted, you will need to install an operating system such as Windows 10 or Linux. Furthermore, Intel has designed this NUC with a slim design so you can mount it behind a VESA-compatible monitor with an included mounting bracket, letting you maximize desktop space.
  • Customized computing
    The Intel NUC includes a customizable board and chassis that are ready to accept the memory, hard drive, and operating system of your choice.
  • Home entertainment
    With a full-sized HDMI port, turn your Intel NUC into a complete home entertainment system.
  • Pint-sized power
    The Intel NUC has the power of a desktop, packing features for entertainment, gaming, and productivity in a small form factor.
  • Energy optimized, media savvy
    With Intel NUC you get an immersive media experience and responsive interaction while consuming a small amount of power relative to a full-sized PC.
  • Flexibility for future growth
    Due to its portable size and ease of installation, the Intel NUC makes it easy to add devices and scale up rapidly based on changing productivity needs.
Intel Next Unit of Computing Kit NUC7I3BNK - mini PC Core i3 7100U 2.4 GHz - 0 GB - no HDD
PC barebone - mini PC
1 x Intel Core i3 (7th Gen) 7100U / 2.4 GHz (Dual-Core)
Processor Main Features
Intel Virtualization Technology, Intel AES New Instructions
Cache Memory
3 MB L3 Cache
Cache Per Processor
3 MB
RAM
0 GB (installed) / 32 GB (max) - DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel HD Graphics 620 - up to
Audio Output
7.1 channel surround
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2
11.5 cm x 11.1 cm x 3.5 cm
Limited warranty - 3 years
PC barebone
Product Form Factor
Mini PC
Built-in Devices
Infrared receiver
Processor / Chipset
CPU
Clock Speed
2.4 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
L3 Cache - 3 MB
Cache Per Processor
3 MB
RAM
Installed Size
DDR4 SDRAM
SO-DIMM 260-pin
Slots
2 (Total) / 2 (empty)
Dual channel memory architecture
Hard Drive
No HDD
Storage Controller
SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
SDXC UHS-I Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
HDMI, DisplayPort
Max Monitors Supported
3
Audio Output
Sound Output Mode
High Definition Audio
Ethernet Controller
Intel I219-V
Wireless LAN Supported
Wireless NIC
Intel Dual Band Wireless-AC 8265
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2
Bays
1 (total) / 1 (free) x internal M.2 2242/2280
Slots
2 (total) / 2 (free) x SO-DIMM 260-pin
4 x USB 3.0 - Type A (2 front, 2 rear) (one of them is fast-charging) , 2 x USB 2.0 (2 internal) , 1 x HDMI , 1 x headphones/microphone - mini-jack , 1 x LAN (Gigabit Ethernet) - RJ-45 , 1 x DisplayPort/USB-C 3.1 Gen 2 , 2 x SATA-600 (2 internal)
VESA mounting kit, processor badge
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ICES-003, EN55024, RoHS, UL 60950-1, IEC 60950-1, EN 60950-1, AS/NZS 4268, WEEE, FCC CFR47 Part 15 C, FCC CFR47 Part 15 B, VCCI V-3, VCCI V-2, EN 62311, VCCI V-4, Directive 2012/19/EU, Directive 2011/65/EU, KN24, China RoHS, CNS 13438, ETSI EN 301 489-17, KN32, ETSI EN 301 489-1, ETSI EN 301 893, AS/NZS 2772.2, FCC CFR47 Part 15 E, CISPR 32, EN 55032, ETSI EN 301 328, CAN/CSA-C22.2 No. 60950-1
Power adapter
Power Provided
65 Watt
11.5 cm
11.1 cm
3.5 cm
