Growing businesses need a reliable server solution for web servers, file and print servers, e-mail servers, storage servers and vertical-specific business applications. A general-purpose entry server platform plays a fundamental role in the success of a workgroup, department, and small- to medium- sized business or high performance computing (HPC). The Intel Server Board S3420GP provides server-class performance without sacrificing cost-effectiveness or reliability.
Intel Xeon processor 3400 series
Significant performance increases with microarchitecutre and delivers world-class performance and superior energy/power efficiency. -
Intel 3420 chipset
Provide enterprise performance and reliability. -
6 DIMM slots for DDR3 1066/1333 MHz
Ensure ample capacity and energy-efficient performance for any application.
- Intel Server Board S3420GPLC - motherboard - ATX - LGA1156 Socket - i3420
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel 3420
- Processor Socket
- 1 x LGA1156 Socket
- Compatible Processors
- Quad-Core Xeon 3400 series
- RAM Supported
- 6 DIMM slots - DDR3, ECC, registered, unbuffered
- Storage Ports
- 6 x SATA
- Graphics
- ServerEngines Pilot II
- Dedicated Video Memory
- 64 MB DDR2 SDRAM
- LAN
- 2 x Gigabit Ethernet
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel 3420
- Processor Socket
- LGA1156 Socket
- Max Processors Qty
- 1
Supported RAM
- Technology
- DDR3
- Supported RAM Integrity Check
- ECC
- Registered or Buffered
- Registered, unbuffered
Graphics
- Graphics Controller
- 64 MB DDR2 SDRAM
LAN
- Network Controller
- Intel 82574L
- Network Interfaces
- Expansion Slots
- 1 x CPU , 6 x DIMM 240-pin , 1 x PCIe 2.0 x8 , 1 x PCIe 2.0 x8 , 1 x PCIe 2.0 x4 , 1 x PCI (5 V)
- Storage Interfaces
- SATA-300 -connectors: 2 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- 4 x USB 2.0 , 2 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x serial
- BIOS Type
- Intel
- BIOS Features
- IPMI support
- 30.5 cm
- 24.4 cm
