Based on the new Intel 82580 Gigabit Ethernet Controller, the Intel Ethernet I340-T4 Server Adapter is Intel's fourth generation of PCIe GbE adapter. This adapter showcases the industry's first fully integrated quad-port PCIe Gen2 GbE controller, providing a smaller footprint and lower power dissipation. In addition, the Intel Ethernet I340-T4 Server Adapter offers advanced features, including support for multi-core processors and server virtualization, as well as a scalable PCI Express Gen 2.0 interface. Intel's first eco-friendly halogen-free board combines low-power and cost for the best price/performance ratio in a quad-port solution available today.
Intel Ethernet Server Adapter I340-T4 - It just works!
Halogen free
Leadership in an environmentally friendly ecosystem. -
RoHS compliant
Compliant with the European Union directive 2002/95/EC to reduce the use of hazardous materials. -
Low-profile
Enables higher bandwidth and throughput from standard and low-profile PCIe slots and servers. -
Load balancing on multiple CPUs
Increases performance on multi-processor systems by efficiently balancing network loads across CPU cores. -
iSCSI remote boot support
Provides centralized storage area network (SAN) management at a lower cost than competing iSCSI solutions.
- Intel Ethernet Server Adapter I340-T4 - network adapter - PCIe 2.0 x4 - Gigabit Ethernet x 4
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 2.0 x4
- PCI Specification Revision
- PCIe 2.0
- Ports
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- TCP/IP, UDP/IP, ARP
- Processor
- 1 x Intel 82580
- IEEE 802.3, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP)
- Microsoft Certification
- Compatible with Windows 7
- Limited lifetime warranty
- Network adapter
- Form Factor
- PCIe 2.0
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- Remote Management Protocol
- SNMP, RMON
- Status Indicators
- Port transmission speed, link/activity
- Flow control, packet filtering, IPv6 support, VLAN Stacking, TCP/IP offloading, VMDq
Processor / Memory
- Processor
- 1 x Intel 82580
- 4 x 1000Base-T - RJ-45
- Compatible Slots
- 1 x PCI Express 2.0 x4 - low-profile
- Included Accessories
- Full-height bracket
- FCC Class B certified, UL, VCCI, C-Tick, BSMI, RoHS, KCC
- Software Included
- Intel PROSet
- Limited warranty - lifetime , Limited warranty - money back guarantee - 90 days
- 0 °C
- 55 °C
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.45 |
