Intel Fibre module for XXV710
Quicklinx: D5LPWS00 Mfr#: E25GSFP28SR
Type: Modules
£41.36 ex VAT
£49.63 inc VAT
The Intel Ethernet SFP28 Optic is intended for customers that are deploying 25GbE, but is also backwards compatible to 10GbE, offering a natural migration path for customers who need more bandwidth.
  • Enhanced connectivity
    The Intel Ethernet SFP28 Optics module offers robust wired connectivity, supporting both 10 Gigabit and 25 Gigabit Ethernet for versatile network integration. Its Plug-and-Play module form factor ensures easy installation and integration into existing systems, making it a seamless upgrade for enhanced network performance.
  • Extended reach
    Designed to maximize network performance, this transceiver module boasts a maximum transfer distance of 100 m, ensuring reliable connections across extended distances. This feature is particularly beneficial for large-scale operations and data centers, where long-distance communication is essential.
Intel Ethernet SFP28 Optics - SFP28 transceiver module - 10GbE, 25GbE
Plug-in module
Cabling Type
10GBase-SR, 25GBase-SR
Data Transfer Rate
25.78 Gbps
Optical Wave Length
850 nm
10GbE, 25GbE
Max Transfer Distance
100 m
Ethernet Converged Network Adapter XXV710, XXV710-DA1; Ethernet Network Adapter XXV710-DA2
Plug-in module
Wired
Cabling Type
10GbE, 25GbE
Data Transfer Rate
25.78 Gbps
Optical Wave Length
850 nm
100 m
1 x Ethernet 25GBase-SR
Lead-Free, RoHS
1.2 Watt
70 °C
Intel Ethernet Converged Network Adapter XXV710, XXV710-DA1 , Intel Ethernet Network Adapter XXV710-DA2
Type: Modules
Brand: Intel
