The Intel Ethernet SFP28 Optic is intended for customers that are deploying 25GbE, but is also backwards compatible to 10GbE, offering a natural migration path for customers who need more bandwidth.
Enhanced connectivity
The Intel Ethernet SFP28 Optics module offers robust wired connectivity, supporting both 10 Gigabit and 25 Gigabit Ethernet for versatile network integration. Its Plug-and-Play module form factor ensures easy installation and integration into existing systems, making it a seamless upgrade for enhanced network performance. -
Extended reach
Designed to maximize network performance, this transceiver module boasts a maximum transfer distance of 100 m, ensuring reliable connections across extended distances. This feature is particularly beneficial for large-scale operations and data centers, where long-distance communication is essential.
- Intel Ethernet SFP28 Optics - SFP28 transceiver module - 10GbE, 25GbE
- Form Factor
- Plug-in module
- Cabling Type
- 10GBase-SR, 25GBase-SR
- Data Transfer Rate
- 25.78 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 10GbE, 25GbE
- Max Transfer Distance
- 100 m
- Designed For
- Ethernet Converged Network Adapter XXV710, XXV710-DA1; Ethernet Network Adapter XXV710-DA2
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 10GbE, 25GbE
- 25.78 Gbps
- 850 nm
- 100 m
- 1 x Ethernet 25GBase-SR
- RoHS, Lead-Free
- 1.2 watt
- 0 °C
- 70 °C
- Designed For
- Intel Ethernet Converged Network Adapter XXV710, XXV710-DA1 , Intel Ethernet Network Adapter XXV710-DA2
