The Intel Ethernet SFP+ SR (Short Range - Max link distance is 300 m) Optic is a SFP+ module designed for the Intel Ethernet Converged Network Adapters (X520 family: product codes: E10G42BTDA, E10G41BFSR, E10G42BFSR, E10G41BFLR). This lead free optic module supports rates selectable 1.25 Gb/s to 10.3 Gb/s bit rates. Intel Ethernet - It just works!
Enhanced connectivity
The Intel Ethernet SFP+ SR Optics module offers wired connectivity technology, ensuring stable and high-speed network connections for demanding data environments. -
Versatile network compatibility
With support for both 10 Gigabit and Gigabit Ethernet, this plug-in module seamlessly integrates into existing network infrastructures, providing a flexible solution for upgrading network performance. -
High-speed data transfer
Designed to meet the needs of high-speed data networks, the module's data link protocols support rapid data transfer rates, making it ideal for bandwidth-intensive applications.
- Intel Ethernet SFP+ SR Optics - SFP+ transceiver module - 1GbE, 10GbE
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX, 10GBase-SR
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE, 10GbE
- Designed For
- Ethernet Converged Network Adapter X520-DA2, X520-SR1, X520-SR2, X710-DA4; Ethernet Server Adapter X520-SR2
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE, 10GbE
- 850 nm
- 1 x Ethernet 10GBase-SR
- Compatible Slots
- 1 x SFP+
- Designed For
- Intel Ethernet Converged Network Adapter X520-DA2, X520-SR1, X520-SR2, X710-DA4 ¦ Intel Ethernet Server Adapter X520-SR2
