Intel Ethernet Server Adapter X520-SR2 - Network adapter - PCI Express 2.0x8 low profile
Quicklinx: 67NDWS00 Mfr#: E10G42BFSR
Wired / Wireless: Wired
Protocol: Fibre Channel over Ethernet (FCoE), 10 Gigabit Ethernet, Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
£251.73 ex VAT
£302.07 inc VAT
The Intel Ethernet 10 Gigabit Converged Network Adapter X520-SR2 enables data center transformation by delivering a reliable, unified 10GbE short range fiber optic connection. Advanced platform scalability features include: Receive Side Coalescing, Intel Ethernet Flow Director, and support for PCI Express Gen2. Intel VT-c delivers industry-leading I/O virtualization capabilities, including support for Single Route I/O virtualization (SR-IOV) and Virtual Machine Device Queues (VMDq). The Intel Ethernet Converged Network Adapter X520 provides advanced unified networking capabilities, including support for iSCSI, NFS, and FCoE. The Intel Ethernet Converged Network Adapter X520 facilitates greater network infrastructure consolidation and is the best choice for I/O virtualization. Intel Ethernet - it just works!
  • Low-profile
    Enables higher bandwidth and throughput from standard and low-profile PCIe slots and servers.
  • Load balancing on multiple CPUs
    Increases performance on multi-processor systems by efficiently balance CPU cores when used with Receive-Side Scaling (RSS) from Microsoft or scalable I/O on Linux.
  • ISCSI remote boot support
    Provides centralized storage area network (SAN) management at a lower cost than other iSCSI solutions.
  • Intel Direct Cache Access (DCA)
    Enables the adapter to pre-fetch the data from memory, avoiding cache misses and improving application response time.
  • MSI-X support
    Minimizes the overhead of interrupts. Load-balancing of interrupt handling between multiple cores/CPUs.
  • Low latency interrupts
    Based on the sensitivity of the incoming data, the adapter can bypass the automatic moderation of time intervals between the interrupts.
  • Header splits and replication in receive
    Helps the driver focus on the relevant part of the packet without the need to parse it.
  • IPsec offload
    Offloads IPsec capability onto the adapter instead of the software to significantly improve I/O throughput and CPU usage.
  • Virtual Machine Load Balancing (VLMB)
    Virtual Machines Load Balancing (VMLB) provides traffic load balancing across virtual switch, port, cable, or adapter failure.
  • Watchdog timer
    Gives an indication to the manageability firmware or external devices that the chip or the driver is not functioning.
Intel Ethernet Converged Network Adapter X520-SR2 - network adapter - PCIe 2.0 x8 - 10GBase-SR x 2
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x8
Ports
10GBase-SR x 2
Cabling Type
Ethernet 10GBase-SR
1GbE, 10GbE, FCoE
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP, IPSec, iSCSI
IEEE 802.3, IEEE 802.1Q, IEEE 802.3ad (LACP)
Network adapter
PCI Express 2.0 x8
Ports
10GBase-SR x 2
Wired
Cabling Type
Ethernet 10GBase-SR
Gigabit Ethernet, 10 Gigabit Ethernet, Fibre Channel over Ethernet (FCoE)
Data Transfer Rate
10 Gbps
Remote Management Protocol
SNMP, RMON
Status Indicators
Port transmission speed, link/activity
VLAN Stacking, VMDq, SR-IOV
2 x 10GBASE-SR - LC multi-mode - x 2
Compatible Slots
1 x PCI Express 2.0 x8
FCC Class B certified, UL, VCCI, C-Tick, BSMI, RoHS
Limited warranty - lifetime , Limited warranty - money back guarantee - 90 days
55 °C
67ND Intel Ethernet SFP+ Optics – SR In Stock £24.08
Protocol: 10 Gigabit Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Brand: Intel
