The X710 adapter family addresses the demanding needs of the next-generation agile data center by providing unmatched features for both server and network virtualization, flexibility for LAN and SAN networks and proven, reliable performance.
One adapter, one price
With the Intel's adapters, iSCSI and FCoE support are included in the price of an adapter. There is no need to purchase multiple adapters or additional licensing for an X710 adapter. It's simple and easy. Everything you need to unify your networking is included in a single SKU. -
Network virtualization
Network virtualization is the next big trend in creating an agile data center. The family of X710 adapters are ready to help you take that next step. -
Energy Efficient Ethernet (EEE)
Reduces power consumption during periods of low data activity. Energy is used to maintain the physical layer transmitters in a "ready state" to transmit data on the wire. During periods of low data traffic, EEE sends a low-power-idle signal to put the transmitters into a "low power state" saving power and cost. When data needs to be sent, EEE sends a normal idle signal to wake up the transmit system before data is due to be sent so there is no degradation of performance.
- Intel Ethernet Converged Network Adapter X710-DA4 - network adapter - PCIe 3.0 x8 - 10 Gigabit SFP+ x 4
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 3.0 x8
- Ports
- 16.7 cm x 11.1 cm
- Data Link Protocol
- 1GbE, 10GbE
- Data Transfer Rate
- 10 Gbps
- TCP/IP, UDP/IP, iSCSI, SMB, NFS
- IEEE 802.3, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.1as, IEEE 802.1Qbg
- System Requirements
- Red Hat Linux 7.0, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Server 2008 R2 x64 Edition, Linux Kernel 2.6.32, FreeBSD 9, VMware ESXi 5.1, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2 x64 Edition, SuSE Linux Enterprise Server 11 SP3, Red Hat Enterprise Linux 6.5, VMware ESXi 5.5, FreeBSD 10, SuSE Linux Enterprise Server 12
- Limited lifetime warranty
- Network adapter
- Form Factor
- Plug-in card
- Ports
- Connectivity Technology
- Wired
- Gigabit Ethernet, 10 Gigabit Ethernet
- 10 Gbps
- Remote Management Protocol
- SNMP, RMON
- Status Indicators
- Port transmission speed, link/activity
- Flow control, VLAN support, packet filtering, IPv6 support, TCP/IP offloading, QoS, VMDq, IPv4 support, teaming support, PXE support, LSO, GSO, RSS, SR-IOV, DCB, ALB, Energy Efficient Ethernet, TSO, checksum offload support, UDP/IP offloading, WDT, iSCSI boot
- 4 x 1Gb Ethernet/10Gb Ethernet - SFP+
- FCC Class B certified, UL, VCCI, C-Tick, BSMI, RoHS, KCC, Directive 2011/65/EU, MSA SFF-8431
- Package Type
- Bulk
- OS Required
- 16.7 cm
- 11.1 cm
- Limited warranty - lifetime
- 0 °C
- 55 °C
Intel Ethernet SFP+ Optics – SR | In Stock | £23.95 |
