Intel DZ77GA-70K S1155 Intel Z77 DDR3 ATX Extreme Series
Quicklinx: 83XJWS00 Mfr#: BOXDZ77GA70K
Once again with the introduction of the Intel Desktop Board DZ77GA-70K, Intel is offering the board of choice for gamers and performance enthusiasts everywhere. In combination with the Intel Visual BIOS, this board is sure to satisfy every need of the performance enthusiasts who seek to push the envelope and squeeze every bit of performance possible out of their systems. Combination of very sophisticated board hardware design and ease of performance tuning and overclocking of the core, graphics, and memory offered by the Intel Visual BIOS make the DZ77GA-70K the best board for the Intel -K processors.
The Intel Visual BIOS offers graphical interface and animated controls which allow you to configure settings faster and take full advantage of your Intel -K processors. Also, included within the Intel Visual BIOS, the Intel overclocking assistant provides single-step overclocking boosts to quickly maximize your gaming advantage. This is a very user-friendly feature which allows easy overclocking of core, graphics, and memory. Intel Visual BIOS operates by your choice of touch screen, keys, or mouse. All controls are literally at your fingertips, in a format you can visualize. When your quest for ultimate performance takes you to extremes, choose the Intel Desktop Board DZ77GA-70K and Intel Visual BIOS.
The advanced power and overclocking capabilities of the DZ77GA-70K board coupled with the dramatic responsiveness improvements delivered by the Intel Smart Response technology provide the board of choice for gamers and media creation enthusiasts alike. Intel Smart Response technology provides SSD like performance and up to 50% improvement in responsiveness as compared to an HDD only system. The Intel Desktop Board DZ77GA- 70K also includes other responsiveness technologies such as Intel Rapid Start technology which allow the user to quickly resume the system from sleep and standby modes.
  • Four DIMM slots
    Designed to support overclocked DDR 3 1600 + O.C.6 memory, delivering up to 32 GB/s memory bandwidth.
  • Two PCI Express 3.0 x16 slots
    Ability to scale to dual x8 graphics support for certified AMD CrossFireX and NVIDIA SLI.
  • Intel Rapid Storage technology
    Performance and reliability with support for RAID 0, 1, 5, 10, and Intel Rapid Recover technology.
  • Intel Smart Response and Intel Rapid Start technologies
    Provides SSD like performance with HDD capacity. Dramatically improves response time when a small capacity SSD is used in conjunction with a large HDD.
  • (8+2) 10-channel Intel high definition audio (7.1)
    Enables high-quality integrated audio that rivals the performance of high-end discrete solutions.
  • Consumer infrared receiver and transmitter
    Supports receiving, learning, and emitting capabilities, controls up to two additional CE devices with your PC, and eliminates the need for a USB CIR dongle.
  • Post code decoder
    Allows for display of post codes for debug along with the included post code quick reference card displaying critical areas to help troubleshoot performance increase roadblocks.
  • Exclusive voltage regulator heat sinks
    Provides reliable and silent cooling for extreme core, graphics, and memory performance tuning.
  • Tweaker switches
    Power and reset switches for overclocking on the go, quick reset, and power on.
  • Lead-free
    Meets all worldwide regulatory requirements for lead-free manufacturing.
Intel Desktop Board DZ77GA-70K - Extreme Series - motherboard - ATX - LGA1155 Socket - Z77
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC
Storage Ports
4 x SATA-600, 4 x SATA-300 (RAID), 1 x eSATA-600
USB / FireWire Ports
4 x USB 3.0 + 1 x FireWire + 4 x USB 2.0 + (4 x USB 3.0 + 1 x FireWire + 4 x USB 2.0 via headers)
Audio
HD Audio (10-channel)
LAN
2 x Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Motherboard - ATX
Chipset Type
Intel Z77 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1900 MHz, 1800 MHz, 1600 MHz, 1333 MHz, 1200 MHz, 1066 MHz, 1866 MHz, 2133 MHz, 2100 MHz
Supported RAM Integrity Check
Non-ECC
Dual channel memory architecture
Audio
Audio Codec
Realtek ALC898
High Definition Audio
LAN
Network Controller
Intel 82574L / Intel 82579
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin (1.5 V) , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x4 , 2 x PCIe 2.0 x1 , 2 x PCI
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 1 x 7pin external SATA - 1 devices
RAID Features
Intel Rapid Storage Technology
1 x HDMI , 1 x FireWire - 6 pin FireWire , 4 x USB 2.0 , 4 x USB 3.0 , 2 x LAN (Gigabit Ethernet) , 1 x TOSLINK , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x audio line-out/microphone - mini-jack , 1 x PS/2 keyboard / mouse
Internal Interfaces
4 x USB 2.0 , 1 x FireWire , 4 x USB 3.0
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
Intel
BIOS Features
ACPI support, DMI support, SMBIOS support, Hyper-Threading Technology, Wfm support
Sleep / Wake Up
RTC (real-time clock) wake up, suspend to RAM (STR), wake on LAN (WOL), wake on PCI device, wake on USB port, wake on infrared
Hardware Features
Chassis intrusion detection, Intel Active Management Technology (Intel AMT)
C-Tick, BSMI, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, RoHS, FCC CFR47 Part 15, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, BSMI CNS 13438, FCC CFR47 Part 15 B, CSA C22.2 No. 60950-1, VCCI V-3
30.5 cm
24.4 cm
Package Type
Retail
ENERGY STAR Certified
Limited warranty - 3 years
