The 802.11 ac, dual-band, 2 x 2 Wi-Fi plus Bluetooth adapter that lets you move at the speed of life with faster speeds, higher capacity, broader coverage, and longer battery life. Combined with 4th generation Intel Core processors and exceptional Intel wireless innovations, the Intel Dual Band Wireless-AC 7260 dramatically reshapes your connected experience at home, work, or on the go.
Ultimate Wi-Fi performance more speed, coverage, larger capacity
It delivers dramatically faster Wi-Fi speeds than 802.11n, more capacity for more users, broader coverage, and better battery life. -
Bluetooth 4.0 smart ready
Dual-mode Bluetooth 4.0 connects to the newest low-energy Bluetooth products, as well as your familiar devices, such as headsets, keyboard, mice, and more. -
Intel wireless display
Watch your PC or Ultrabook content instantly without wires on the big HD screen with stunning image clarity and sound. Intel wireless display gives you a serious entertainment upgrade: stream movies, videos, games, photos, connect with friends, and more - experience it all. -
Intel Smart Connect technology
Automatically updates important content even while your Ultrabook is asleep or for quicker Internet access on resume. -
Intel Wi-Fi HotSpot assistant
Experience the power of instant connectivity to millions of free and paid Wi-Fi hotspots worldwide. Your Ultrabook auto-connects to available Wi-Fi hotspots as you roam - no more annoying manual logon processes at each hotspot. Use with Intel Smart Connect technology to automatically refresh your favorite cloud content, even as your Ultrabook sleeps. -
Business class wireless suite
It supports Intel vPro technology, Intel Active Management technology, and Intel PROSet/wireless enterprise software for enterprise Wi-Fi client manageability, improved security, and streamlined deployment.
- Intel Dual Band Wireless-AC 7260 - network adapter - PCIe Half Mini Card
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express Half Mini Card
- 3 cm x 0.24 cm x 2.68 cm
- Data Link Protocol
- Bluetooth 4.0, Wi-Fi 5
- Data Transfer Rate
- 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11d, IEEE 802.11g, IEEE 802.1x, IEEE 802.3ac, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11h, IEEE 802.11e, IEEE 802.11n, Bluetooth 2.1, Bluetooth 3.0, Bluetooth 4.0
- System Requirements
- Linux, Microsoft Windows 7, Windows 8
- Network adapter
- Form Factor
- Plug-in card
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- 867 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS), Intel Wireless Display (WiDi), Intel Smart Connect Technology
- Compatible Slots
- 1 x PCI Express Half Mini Card
- Encryption Algorithm
- LEAP, 128-bit WEP, 64-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA2
- UL, cUL, CB, IEC 60950-1, FIPS
- OS Required
- 3 cm
- 0.24 cm
- 2.68 cm
- 0 °C
- 80 °C
- 50 - 90% (non-condensing)
