The Next Generation of CPU Design and Technology
The power and performance of CPU’s in recent years have grown ten-fold. The 7th Gen CPU’s from Intel bring new processor technologies and enhance those that already existed. You could be missing out on more CPU capabilities than you know, such as uncompromised gaming, while you stream, chat and share with your community and stunning Ultra HD 4K HDR premium content.
With premium performance and new & enhanced features, a desktop computer based on a 7th Gen CPU from Intel is always ready for real-life productivity, creativity and entertainment. There is a new generation Intel Core processor powered desktop computer to fit a wide range of budgets and needs.
Specs
Processor Number - i3-7100T
No. of Cores - 2
No. of Threads - 4
Processor Base Frequency - 3.40 GHz
Cache - 3 MB
Bus Speed - 100 MHz DMI
TDP - 35 W
Sockets Supported - LGA1151
Intel® Hyper-Threading Technology - Yes
Intel® Virtualization Technology (VT-x) - Yes
Intel smart cache
Intel smart cache is shared cache dynamically allocated to each processor core, based on workload. This efficient, dual-core-optimized implementation increases the probability that each core can access data from the fast cache, significantly reducing latency to frequently used data and improving performance.
- Intel Core i3 7100T / 3.4 GHz processor - Box
- Product Type
- Processor
- Processor Type
- Intel Core i3 7100T (7th Gen)
- Number of Cores
- Dual-Core / 4 threads
- Cache
- 3 MB
- Integrated Graphics
- Intel HD Graphics 630
- Compatible Processor Socket
- LGA1151 Socket
- Processor Qty
- 1
- Clock Speed
- 3.4 GHz
- Manufacturing Process
- 14 nm
- Enhanced SpeedStep technology, Hyper-Threading Technology, Execute Disable Bit capability, Intel Virtualization Technology, Intel 64 Technology, streaming SIMD extensions 4.1, streaming SIMD extensions 4.2, Intel AES New Instructions (AES-NI), Thermal Monitoring Technologies, Intel Virtualization Technology for Directed I/O (VT-d), Idle States, Intel Identity Protection Technology, Intel Secure Key, Intel Advanced Vector Extensions 2 (AVX2.0), Intel TSX-NI, Intel OS Guard, Intel Software Guard Extensions (SGX), Intel Memory Protection Extensions (MPX), Intel Device Protection Technology with Boot Guard
- 3-year warranty
- Product Type
- Processor
- Type / Form Factor
- Number of Cores
- Dual-Core
- Number of Threads
- 4 threads
- Cache
- 3 MB
- Cache Memory Details
- Smart Cache - 3 MB
- Processor Qty
- 1
- Clock Speed
- 3.4 GHz
- LGA1151 Socket
- 14 nm
- Thermal Design Power
- 35 W
- Thermal Specification
- 92 °C
- PCI Express Revision
- 3.0
- PCI Express Configurations
- 1x16, 2x8, 1x8+2x4
- PCI Express Lanes Qty
- 16
- Architecture Features
Integrated Graphics
- Base Frequency
- 350 MHz
- Max Dynamic Frequency
- 1.1 GHz
- Max Supported Memory Size
- 64 GB
- Max Supported Resolution
- 4096x2304@24Hz (HDMI), 4096x2304@60Hz (eDP), 4096x2304@60Hz (DP)
- Intel Clear Video Technology, Intel Clear Video HD Technology, InTRU 3D Technology, Intel Quick Sync Video, Intel Insider, Triple Display Capable
- Package Type
- Intel Boxed
- Limited warranty - 3 years
