Intel Compute Stick Atom Z3735F 1.33GHz 2GB HDMI Windows 8.1
Quicklinx: BBD0WS00 Mfr#: BOXSTCK1A32WFC
  • Atom
  • Bluetooth 4.0
  • IEEE 802.11n
  • Windows 8.1 with Bing 32-bit Edition
With Windows 8.1 packed inside, you can benefit from a free upgrade to Windows 10.
The Intel® Compute Stick. Small, Yet Surprisingly Powerful.
While the Intel® Compute Stick can fit in the palm of your hand, it's what we fit inside of it that is truly remarkable. A quad-core Intel® Atom™ processor and Windows 8.1 operating system.
The Windows version includes 2 GB memory, 32 GB of on-board storage and comes with McAfee® Antivirus Plus for comprehensive protection from Trojans, viruses, spyware and more. The device also come with Wi-Fi* and Bluetooth* for connectivity, a USB port to connect peripherals and a micro SD card slot for additional storage.
Use Your Television for More Than TV
Looking to bring computing to new places? The Intel® Compute Stick is exactly what you're looking for. It transforms any HDMI* TV or monitor into a full computer, allowing you to search the web, share your vacation photos, keep up on your email or do any of the tasks that you do on your computer today. All you need is a wireless keyboard and mouse and you're set.
Transform Your Monitors. And Your Business.
Whether you need to develop some digital signage, add intelligence to a conference room projector or deploy a room full of thin clients, the Intel® Compute Stick has the right blend of performance, cost, and size to do the job. Wherever you need to add a basic computer to run your business, the Intel Compute Stick has you covered.
The Intel® Remote Keyboard Host App allows you to control your Intel® NUC or Intel® Compute Stick from your mobile device (smartphone or tablet).
  • Use your television for more than TV
    Looking to bring computing to new places? The Intel Compute Stick is exactly what you're looking for. It transforms any HDMI TV or monitor into a full computer, allowing you to search the web, share your vacation photos, keep up on your email or do any of the tasks that you do on your computer today. All you need is a wireless keyboard and mouse and you're set.
  • Transform your monitors
    Whether you need to develop some digital signage, add intelligence to a conference room projector or deploy a room full of thin clients, the Intel Compute Stick has the right blend of performance, cost, and size to do the job.
  • Quality, performance, value
    Take it out of the box. Plug it in to your television. You just turned your TV into a powerful computer with ample speed and storage. The Intel Compute Stick takes up so little space and costs so few dollars.
  • Quad-core Intel Atom processor
    This innovative processor delivers max performance but uses minimum power - making the Intel Compute Stick both space and energy efficient.
  • Intel HD graphics
    Exceptional clarity makes for an exceptional visual experience. The Intel Compute Stick delivers HD wow, whether you're viewing videos, games, or photos.
  • Intel HD audio
    Get a high quality, multichannel sound experience, without an audio card. It's truly an immersive media experience that will have your ears seeing stars.
Intel Compute Stick STCK1A32WFC - stick Atom Z3735F 1.33 GHz - 2 GB - flash 32 GB
Personal computer - stick
Intel Atom Z3735F / 1.33 GHz (up to 1.83 GHz, (Quad-Core)
Processor Main Features
Intel Virtualization Technology
Cache Memory
2 MB
Cache Per Processor
2 MB
RAM
2 GB DDR3L SDRAM
Hard Drive
Flash 32 GB - eMMC
Optical Storage
No optical drive
Card Reader
Graphics Controller
Intel HD Graphics - up to
802.11b/g/n, Bluetooth 4.0
OS Provided
Software Included
McAfee AntiVirus Plus
3.76 cm x 10.34 cm x 1.25 cm
54 g
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year
Personal computer
Product Form Factor
Stick
Processor / Chipset
CPU
Intel Atom Z3735F
Clock Speed
1.33 GHz
Max Turbo Speed
1.83 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
Cache Memory
Installed Size
2 MB
Cache Per Processor
2 MB
RAM
Installed Size
2 GB
DDR3L SDRAM
Effective Memory Speed
1333 MHz
Configuration Features
Provided memory is soldered
Hard Drive
Flash - eMMC
1 x 32 GB
Optical Storage
No optical drive
Card Reader
Card reader
Supported Flash Memory Cards
microSD, microSDXC UHS-I Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Intel HD Graphics
Video Interfaces
HDMI
Audio Output
High Definition Audio
Wireless LAN Supported
Wireless NIC
AzureWave AW-NB177NF
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
1 x USB 2.0 , 1 x HDMI
Quantity of Items per Pack
10
HDMI extension cable
ACPI
Power adapter
Operating System / Software
OS Provided
Software
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
6.0
3.76 cm
10.34 cm
1.25 cm
54 g
35 °C
Resources
The following resources are available for the Intel Compute Stick Atom Z3735F 1.33GHz 2GB HDMI Windows 8.1
