Intel 900P 480GB HHHL AIC NVMe SSD
Quicklinx: DCGPWS00 Mfr#: SSDPED1D480GAX1
Form Factor: PCIe card (HHHL)
Capacity: 480GB
Interface: PCI Express 3.0 x4 (NVMe)
Type: Internal hard drive
£471.85 ex VAT
£566.22 inc VAT
Marketing description is not available.
  • Fast load times
    Load rich textures and get fully immersed in deep space. Plus, the drive supports the seamless transitions you're called on to make from in-space dogfighting to on-the-ground combat.
  • Smooth gaming
    The Intel Optane SSD 900P helps ensure you're ready to respond and act quickly in the game's crucial moments.
Intel Optane SSD 900P Series - solid state drive - 480 GB - PCI Express 3.0 x4 (NVMe)
Solid state drive - internal
480 GB
SSD Technology
3D Xpoint (Optane)
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
20nm
PCIe card (HHHL)
230 g
5-year warranty
480 GB
Hardware Encryption
256-bit AES
SSD Technology
3D Xpoint (Optane)
20nm
PCIe card (HHHL)
230 g
Performance
SSD Endurance
8.76 PB
Internal Data Rate
2500 MBps (read) / 2000 MBps (write)
4KB Random Read
550000 IOPS
4KB Random Write
500000 IOPS
Average Latency
10 µs
Reliability
MTBF
1,600,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe)
Compatible Bay
PCIe card (HHHL)
Power Consumption
14 Watt (active) , 5 Watt (idle)
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
50 g @ 11 ms
Shock Tolerance (non-operating)
50 g @ 11 ms
Vibration Tolerance (operating)
2.17 g @ 5-700 Hz
Vibration Tolerance (non-operating)
3.13 g @ 5-800 Hz
Capacity: 480GB
Brand: Intel
Price Range Ex VAT: 300 - 500
