Intel 8 port SAS contoller
Quicklinx: 6L54WS00 Mfr#: SASUC8I
The Intel RAID Controller SASUC8I is ideal for servers and workstations needing high-speed data transfer with the option for entry-level hardware RAID data protection. This RAID controller allows for point-to-point connections with a SAS universal interconnect interface allowing for 1.5 and 3Gbps SATA hard disk drives along with logical SCSI compatibility for the extra reliability and manageability that SAS drives provide.
While other SAS controllers drive large RAID software stacks between the host CPU and controller, the SASUC8I utilizes the embedded CPU in the LSI SAS1068E ASIC to perform RAID 0, 1, and 1E/10E operations. By reducing RAID code overhead, the SASUC8I offers superior internal read/write performance.
  • Cost effective data protection
    Provides a low-cost RAID 0, 1, and 1E/10E solution for entry-level server and workstation environments where high-performance and reliable data protection are required.
  • SAS or SATA storage
    Connect SAS or SATA devices within the array. Use SAS drives for speed, reliability, and scalability; use high-capacity SATA drives for budget-friendly storage.
  • Scalability
    Supports up to 122 physical devices in SAS mode which is ideal for employing JBODs (Just a Bunch Of Disks) or up to 14 devices in RAID 0, 1, 1E/10E mode through direct connect device attachment or through expander backplane support.
  • Ultra thin driver
    LSI Fusion-MPT architecture provides over 140,000 I/Os per second while communicating over the PCI Express 8-lane host bus.
  • Increased IT productivity
    It includes a suite of tools that are common across all Intel SAS/SATA RAID solutions, for easy installation and advanced management.
Intel RAID Controller SASUC8I - storage controller (RAID) - SATA 3Gb/s / SAS - PCIe x8
Storage controller (RAID) - plug-in card - low profile
Bus Type
PCIe x8
SATA 3Gb/s / SAS
Data Transfer Rate
3 Gbit/s
Supported Devices
Hard drive, disk array (RAID)
Channel Qty
8
Max Storage Devices Qty
14
RAID Level
RAID 0, RAID 1, JBOD, RAID 1E, RAID 10E
Microsoft Windows XP, Microsoft Windows Server 2003, SuSE Linux Enterprise Server 9, SuSE Linux Enterprise Server 10, Microsoft Windows Server 2008, Red Hat Enterprise Linux 4 or later
Microsoft Certification
Works with Windows Vista
16.8 cm x 6.4 cm
Host Bus
PCIe x8
Storage Controller
SATA 3Gb/s / SAS
Data Transfer Rate
3 Gbit/s
Supported Devices
Channel Qty
8
14
RAID Level
LSI LSISAS1068E
2 x SATA 3Gb/s / SAS - 36 pin 4i Mini MultiLane
Compatible Slots
1 x PCI Express x8 - low-profile
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
16.8 cm
6.4 cm
60 °C
5 - 90%
