Intel 450GB DC P3520 Series 2.5" PCIe 3.0 x4 MLC SSD
Quicklinx: CBLXWS00 Mfr#: SSDPE2MX450G701
With the Intel® SSD DC P3520 Series, you can now transition your data center storage solutions from SATA SSDs and HDDs in a cost-effective manner. Built on Intel 3D NAND, the Intel® SSD DC P3520 Series is optimized for high density data center/enterprise configurations. Combined with the low latency and high bandwidth of the NVMe* specification, the Intel® DC P3520 Series enables up to 4.7x the performance of SATA?making it ideal for read-intensive workloads. The consistently amazing performance of the Intel® SSD DC P3520 Series provides fast data streams directly to the processor, such as the high-performance Intel® Xeon® processor, for efficient server data transfers. The Intel® SSD DC P3520 Series is built with the data integrity, drive reliability, and performance consistency you expect from Intel.
  • Intel 3D NAND SSDs
    The SSD data center P3520 Series is part of the Intel 3D NAND SSD family of products built on breakthrough 3D NAND and delivered by a proven and trusted supplier, Intel 3D NAND SSDs transform the economics of storage.
  • Next generation SSD performance
    As Intel's newest solid state storage solution the Intel SSD DC P3520 Series offers the speed of PCle performance making it the ideal choice for read- intensive workloads.
  • High performance, low cost
    The Intel SSD data Center family for PCle offers consistently amazing performance that provides fast data streams directly to the processor, such as the high-performance Intel Xeon processor, for efficient server data transfers.
  • For new designs or upgrading existing
    Systems Intel's compatibility validation team and robust PCle compliance programs enable the DC P3520 Series' broad compatibility In mainstream operating systems the DC P3520 Series works straight out of the box; it can be quickly integrated into new designs and existing systems can b easily upgraded.
Intel Solid-State Drive DC P3520 Series - SSD - 450 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
450 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
PCIe 3.0 x4 (NVMe)
Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, End-to-end data protection, 3D NAND Technology
125 g
5-year warranty
450 GB
Hardware Encryption
256-bit AES
PCIe 3.0 x4 (NVMe)
125 g
Performance
SSD Endurance
590 TB
Internal Data Rate
1200 MBps (read) / 600 MBps (write)
4KB Random Read
145000 IOPS
4KB Random Write
19000 IOPS
Average Latency
20 µs
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe)
Power Consumption
9 Watt (read) , 8 Watt (write) , 4 Watt (idle)
Limited warranty - 5 years
35 °C
Shock Tolerance (operating)
1000 g @ 0.5 ms
Shock Tolerance (non-operating)
1000 g @ 0.5 ms
Vibration Tolerance (operating)
2.17 g
Vibration Tolerance (non-operating)
3.13 g
