Intel 2TB DC P3520 Series 2.5" PCIe 3.0 x4 MLC SSD
Quicklinx: CBM1WS00 Mfr#: SSDPE2MX020T701
The Intel Solid-State Drive DC S3500 series combines fast, consistent read performance with strong data protection and low active power levels to provide superior quality of service for video conferencing, big data analytics, or virtual client applications. Consistently low read latencies of 50 µs typical (500 µs max for 99.9 percent of the time) along with a tight distribution of up to 75,000 input/output operations per second (IOPS)1 delivers a high-performance, reliable, and efficient SSD specifically designed for data center application upgrades.
  • Enhanced reliability
    With an MTBF of 2,000,000 hours, the Intel Solid-State Drive DC P3520 Series offers exceptional reliability and durability, ensuring your data is safe over extensive use.
  • Advanced security
    Equipped with 256-bit AES hardware encryption, this solid state drive provides high-level security for your data, protecting against unauthorized access and breaches.
  • Efficient power management
    Featuring a smart power consumption mode that ranges from a mere 4 W in idle to 12 W during write operations, this SSD balances performance with energy efficiency.
  • High-speed performance
    Boasting an internal data rate of up to 1700 MB/s for reading and 1350 MB/s for writing, the drive accelerates data access and transfer, enhancing productivity and user experience.
  • Durable design
    Designed to withstand physical shocks and vibrations, this SSD ensures data integrity and drive performance even in harsh conditions, making it ideal for mobile and desktop applications.
Intel Solid-State Drive DC P3520 Series - SSD - 2 TB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Multi-level cell (MLC)
PCIe 3.0 x4 (NVMe)
Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, End-to-end data protection, 3D NAND Technology
125 g
5-year warranty
2 TB
Hardware Encryption
256-bit AES
PCIe 3.0 x4 (NVMe)
125 g
Performance
SSD Endurance
2490 TB
Internal Data Rate
1700 MBps (read) / 1350 MBps (write)
4KB Random Read
375000 IOPS
4KB Random Write
26000 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe)
Power Consumption
10 Watt (read) , 12 Watt (write) , 4 Watt (idle)
Limited warranty - 5 years
35 °C
Shock Tolerance (operating)
1000 g @ 0.5 ms
Shock Tolerance (non-operating)
1000 g @ 0.5 ms
Vibration Tolerance (operating)
2.17 g
Vibration Tolerance (non-operating)
3.13 g
