Intel 256GB 600p Series M.2 PCIe 3.0 x4 TLC SSD
Quicklinx: CBLSWS00 Mfr#: SSDPEKKW256G7X1
Take your PC to a new level of responsiveness. Designed for work and play, the Intel® SSD 600p Series accelerates office applications, 4K video playback, HD content creation, and everyday gaming. Compared to traditional hard drives, the Intel SSD 600p Series delivers power efficiency, a small form factor for system flexibility, and 17x better performance. The Intel SSD 600p Series features the fast PCIe 3 x4 interface and is part of the Intel® 3D NAND SSD family of products. The only thing more amazing than Intel technology inside is what you’ll do with it on the outside.
  • Optimized for an accelerated PC experience
    Delivering performance that is up to 17 times faster than hard disk drives, and 3 times faster than SATA SSDs, you get faster boot, application-load, file-transfer and copy times.
  • Manufactured for reliability
    Validated on a massive scale with thousands of configurations, and tested beyond industry standards, Intel SSDs deliver an Annualized Failure Rate (AFR) that's eight times better than traditional hard drives.
  • Made for easy installation
    A small M.2 (80 mm) form factor offers a wide range of capacities and simply plugs into M.2 - M key slots on major motherboards.
  • Featuring breakthrough 3D NAND from Intel
    By stacking layers of data storage cells vertically, Intel 3D NAND SSDs create denser storage, delivering significant cost savings and lower-power usage along with greater reliability, speed, and overall performance.
Intel Solid-State Drive 600p Series - SSD - 256 GB - PCIe 3.0 x4 (NVMe)
Solid state drive - internal
256 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
Triple-level cell (TLC)
M.2 2280
PCIe 3.0 x4 (NVMe)
Smart Response Technology, Rapid Start Technology
3.5 mm x 80 mm x 22 mm
40 g
5-year warranty
256 GB
Hardware Encryption
256-bit AES
M.2 2280
PCIe 3.0 x4 (NVMe)
3.5 mm
80 mm
22 mm
40 g
Performance
SSD Endurance
72 TB
Internal Data Rate
1570 MBps (read) / 540 MBps (write)
4KB Random Read
71000 IOPS
4KB Random Write
112000 IOPS
Reliability
MTBF
1,600,000 hours
Non-Recoverable Errors
1 per 10^15
Expansion & Connectivity
1 x PCI Express 3.0 x4 (NVMe)
Compatible Bay
M.2 2280
Power Consumption
100 mW (active) , 40 mW (idle)
RoHS
Limited warranty - 5 years
70 °C
Vibration Tolerance (operating)
2.17 g @ 5-700 Hz
Vibration Tolerance (non-operating)
3.13 g @ 5-800 Hz
