The Intel SSD DC S3500 Series combines fast, consistent read performance with strong data protection and low active power levels to provide superior quality of service for video conferencing, big data analytics, or virtual client applications. Consistently low read latencies of 50 µs typical (500 µs max for 99.9% of the time) along with a tight distribution of up to 75,000 input/output per second (IOPS) delivers a high-performance, reliable, and efficient SSD specifically designed for data center application upgrades.
Robust durability
Designed to withstand operating shocks of up to 1000 g @ 0.5 ms and a wide range of operating temperatures from 0°C to 70°C, this solid-state drive offers exceptional durability and reliability for various computing environments. -
Enhanced security
Equipped with 256-bit AES compliance and Enhanced Power Loss Data Protection, this drive ensures your data is secure and protected, even in the event of unexpected power loss. -
High performance
With a data transfer rate of 600 MBps and support for Native Command Queuing (NCQ), this SSD delivers fast and efficient performance, significantly reducing data transfer times and enhancing overall system responsiveness.
- Intel Solid-State Drive DC S3500 Series - SSD - 240 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 240 GB
- NAND Flash Memory Type
- 20nm multi-level cell (MLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Native Command Queuing (NCQ), End-to-end data protection (ANSI), SMART Command Transport (SCT), Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, S.M.A.R.T., 256-bit AES
- 60.95 mm x 100.45 mm x 7 mm
- 70 g
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Capacity
- 240 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 60.95 mm
- 100.45 mm
- 7 mm
- 70 g
Performance
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps (read) / 260 MBps (write)
- 4KB Random Read
- 75000 IOPS
- 4KB Random Write
- 7500 IOPS
Reliability
- MTBF
- 2,000,000 hours
- Non-Recoverable Errors
- 1 per 10^17
Expansion & Connectivity
- 1 x SATA 6 Gb/s
- Compatible Bay
- 2.5"
- Power Consumption
- 3.1 Watt (active) , 0.9 Watt (idle)
- UL, VCCI, C-Tick, BSMI, EN55022, ICES-003, EN55024, CISPR 22, FCC Part 15 B, RoHS, UL 60950-1 Second Edition, KCC, EN 60950-1 Second Edition
- Package Type
- OEM
- Limited warranty - 5 years
- 0 °C
- 70 °C
- 5 - 95%
- Shock Tolerance
- 1000 g @ 0.5ms (operating) / 1000 g @ 0.5ms (non-operating)
- Vibration Tolerance
- 2.17 g @ 5-700 Hz (operating) / 3.13 g @ 5-800 Hz (non-operating)
