Intel 180GB 535 Series 2.5" 7mm SATA 6Gb/s SSD
Quicklinx: BBH4WS00 Mfr#: SSDSC2BW180H601
The Intel SSD 535 series combines quality, performance, and low power consumption for outstanding performance in a small form factor. With power-efficient performance and the 16 m NAND technology, the Intel SSD 535 series is designed for consumer and embedded platforms with demanding consumer client applications and intense multi-tasking requirements.
  • Small form factors
    The Intel SSD 535 Series M.2 form factor delivers outstanding performance for thin and light computing devices. Intel's SSD M.2 form factor requires far less space than a traditional 2.5- inch form factor storage device. Intel SSD 535 Series is also available in traditional 2.5-inch form factors, providing a variety of solid-state technology solutions.
  • NAND technology
    Intel SSD 535 Series uses the 16nm NAND technology. You will also benefit from the high quality and reliability you've come to expect from Intel. The Intel SSD 535 Series boasts power and space savings, reliability, and peace of mind.
Intel Solid-State Drive 535 Series - SSD - 180 GB - SATA 6Gb/s
Solid state drive - internal
180 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
16nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
DevSleep mode, End-to-end data protection, Windows WHCK certified, Hot-Plug Support, S.M.A.R.T., 256-bit AES
100.45 mm x 7 mm x 69.85 mm
78 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
180 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
100.45 mm
7 mm
69.85 mm
78 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 490 MBps (write)
4KB Random Read
41000 IOPS
4KB Random Write
80000 IOPS
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
165 mW (active) , 55 mW (idle) , 5 mW (sleep)
UL, VCCI, C-Tick, BSMI, FCC Part 15 B, RoHS, UL 60950-1 Second Edition, KCC, EN 60950-1 Second Edition, SATA-IO, EN 55024:2010, EN 55022:2010, CISPR 22:2008
Limited warranty - 5 years
70 °C
5 - 95%
Shock Tolerance (operating)
1500 g @ 0.5 ms
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (operating)
2.17 g @ 5-700 Hz
Vibration Tolerance (non-operating)
3.13 g @ 5-800 Hz
