Intel 150GB DC S3520 Series 2.5" 7mm SATA 6Gb/s MLC SSD
Quicklinx: CBMFWS00 Mfr#: SSDSC2BB150G701
The Intel Solid-State Drive DC S3500 series combines fast, consistent read performance with strong data protection and low active power levels to provide superior quality of service for video conferencing, big data analytics, or virtual client applications. Consistently low read latencies of 50 µs typical (500 µs max for 99.9 percent of the time) along with a tight distribution of up to 75,000 input/output operations per second (IOPS)1 delivers a high-performance, reliable, and efficient SSD specifically designed for data center application upgrades.
  • Enhanced durability
    With a shock acceleration tolerance of 1000 g for both operating and non-operating states, this solid-state drive offers exceptional durability and reliability, ensuring your data remains safe even in the event of physical impacts.
  • Optimized power efficiency
    Featuring an active power consumption of just 2.2 W and an idle power consumption of 530 mW, this drive is designed for energy efficiency, reducing operational costs and extending battery life in portable devices.
  • Advanced security
    Equipped with 256-bit AES hardware encryption, the drive provides high-level security for your data, ensuring it remains protected against unauthorized access.
  • High performance
    Boasting an internal data rate of 180 MBps for reading and 165 MBps for writing, along with 43000 IOPS for 4KB random reads and 31000 IOPS for 4KB random writes, this drive delivers fast and reliable performance for all your storage needs.
  • Extended reliability
    With an MTBF of 2,000,000 hours, this solid-state drive offers long-term reliability, making it a smart investment for critical data storage solutions.
Intel Solid-State Drive DC S3520 Series - solid state drive - 150 GB - SATA 6Gb/s
Solid state drive - internal
150 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
16nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, End-to-end data protection, 3D NAND Technology
7 mm
60 g
5-year warranty
150 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
7 mm
60 g
Performance
SSD Endurance
412 TB
Internal Data Rate
180 MBps (read) / 165 MBps (write)
4KB Random Read
43000 IOPS
4KB Random Write
31000 IOPS
Average Latency
30 µs
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
2.2 Watt (active) , 530 mW (idle)
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1000 g @ 0.5 ms
Shock Tolerance (non-operating)
1000 g @ 0.5 ms
Vibration Tolerance (operating)
2.17 g @ 5-700 Hz
Vibration Tolerance (non-operating)
3.13 g @ 5-800 Hz
