Intel 120GB 535 Series 2.5" 7mm SATA 6Gb/s SSD
Quicklinx: BBH3WS00 Mfr#: SSDSC2BW120H601
The next generation of consumer computing
The Intel® SSD 535 Series combines quality, performance, and low power consumption for outstanding performance in a small form factor. With power-efficient performance and the latest 16nm NAND technology, the Intel SSD 535 Series is designed for consumer and embedded platforms with demanding consumer client applications and intense multi-tasking requirements.
Designed for a wide range of consumer and embedded platforms, including Ultrabook, traditional desktops and laptops, mini computers, and digital signage, as well as the latest tablets and small form factor mobile systems, Intel Solid-State Drive 535 Series combines high quality, reliable performance and low power consumption for space conscious computing.
The Intel SSD 535 Series accelerates platform performance with sequential reads of up to 540 megabytes and sequential writes of up to 490 megabytes per second (MB/s) and random read and write input/output operations (IOPS) of up to 48K and 80K respectively. In addition to strong performance gains, Intel SSD 535 Series provides extended battery life through low power modes. Idle power consumption of Intel SSD 535 Series is reduced by >90% over a typical hard disc drive, thereby reducing power consumption from watts to milliwatts. When the Intel SSD 535 Series is coupled with a 4th or 5th generation Intel Core-based platform, advanced power mode settings reduce power dissipation another order of magnitude - from milliwatts to microwatts.
  • Small form factors
    The Intel SSD 535 Series M.2 form factor delivers outstanding performance for thin and light computing devices. Intel's SSD M.2 form factor requires far less space than a traditional 2.5- inch form factor storage device. Intel SSD 535 Series is also available in traditional 2.5-inch form factors, providing a variety of solid-state technology solutions.
  • NAND technology
    Intel SSD 535 Series uses the 16nm NAND technology. You will also benefit from the high quality and reliability you've come to expect from Intel. The Intel SSD 535 Series boasts power and space savings, reliability, and peace of mind.
Intel Solid-State Drive 535 Series - solid state drive - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
16nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
DevSleep mode, End-to-end data protection, Windows WHCK certified, Hot-Plug Support, S.M.A.R.T., 256-bit AES
100.45 mm x 7 mm x 69.85 mm
78 g
Microsoft Certification
Compatible with Windows 7
5-year warranty
120 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
100.45 mm
7 mm
69.85 mm
78 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
540 MBps (read) / 480 MBps (write)
4KB Random Read
24000 IOPS
4KB Random Write
80000 IOPS
Reliability
MTBF
1,200,000 hours
Non-Recoverable Errors
1 per 10^16
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
165 mW (active) , 55 mW (idle) , 5 mW (sleep)
UL, VCCI, C-Tick, BSMI, FCC Part 15 B, RoHS, UL 60950-1 Second Edition, KCC, EN 60950-1 Second Edition, SATA-IO, EN 55024:2010, EN 55022:2010, CISPR 22:2008
Limited warranty - 5 years
70 °C
5 - 95%
Shock Tolerance (operating)
1500 g @ 0.5 ms
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (operating)
2.17 g @ 5-700 Hz
Vibration Tolerance (non-operating)
3.13 g @ 5-800 Hz
