Intel 10 Gigabit XF SR Server Adapte
Quicklinx: 54XWWS00 Mfr#: EXPX9501AFXSR
10 Gigabit Ethernet has moved past the early adoption stage and is rapidly becoming mainstay for backbones within enterprise and service provider networks. The escalating deployments of servers with multi-core processors and demanding applications such as High Performance Computing (HPC), database clusters, and video-on-demand are driving the need for 10 Gigabit connections. Based on the Intel 82598EB 10 Gigabit Ethernet controller, the next-generation Intel 10 Gigabit XF Server Adapters are designed to meet the throughput and latency requirements of bandwidth-hungry applications, while offering a very low power envelope for energy efficiency. Ideal for slot-constrained environments, the Intel 10 Gigabit XF Dual Port Server Adapter provides a simplified alternative to multiple 1 Gbps server adapters.
Intel 10 Gigabit - it just works!
Intel 10 Gigabit XF SR Server Adapter - network adapter - PCIe 2.0 x8 - 10GBase-SR
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 2.0 x8
PCI Specification Revision
PCIe 2.0
Ports
10GBase-SR
16.7 cm x 7.9 cm
Cabling Type
Ethernet 10GBase-SR
10GbE
Max Transfer Distance
300 m
Data Transfer Rate
10 Gbps
Network / Transport Protocol
TCP/IP, UDP/IP
1 x Intel 82598EB
IEEE 802.3, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3ad (LACP), WfM 2.0
Microsoft Windows Server 2003, SuSE Linux 9.2 Professional, Red Hat Enterprise Linux 4, Red Hat Fedora Core, Microsoft Windows Vista, FreeBSD 5.x or later, SuSE Linux Enterprise Server 10
Microsoft Certification
Compatible with Windows 7
Network adapter
PCI Express 2.0 x8
PCIe 2.0
Ports
10GBase-SR
Wired
Cabling Type
Ethernet 10GBase-SR
10 Gigabit Ethernet
Data Transfer Rate
10 Gbps
300 m
TCP/IP, UDP/IP
Remote Management Protocol
SNMP, DMI 2.0
Status Indicators
Link OK, link/activity
Flow control, fault tolerance, load balancing, VLAN support, packet filtering, IPv6 support, Intel I/OAT, VMDq
Processor / Memory
1 x Intel 82598EB
1 x 10GBASE-SR - LC multi-mode - x 2
Compatible Slots
1 x PCI Express 2.0 x8 - low-profile
Full-height bracket
FCC Class B certified, UL, VCCI, C-Tick, BSMI, MIC, RoHS, Lead-Free
Software Included
Intel PROSet
16.7 cm
7.9 cm
Limited warranty - lifetime
55 °C
