Intel 1.2TB DC S3520 Series 2.5" 7mm SATA 6Gb/s MLC SSD
Quicklinx: CBMSWS00 Mfr#: SSDSC2BB012T701
Modernize your data center storage and make the switch from HDDs to the Intel® SSD DC S3520 Series. As part of the Intel® 3D NAND SSD family of products, the Intel SSD DC S3520 Series delivers the unmatched combination of data integrity, performance consistency, and drive reliability. With a much lower active write power than the Intel® SSD DC S3510 Series, the Intel SSD DC S3520 Series enables the delivery of 35% more rack performance per watt.
Intel Solid-State Drive DC S3520 Series - SSD - 1.2 TB - SATA 6Gb/s
Solid state drive - internal
1.2 TB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
16nm multi-level cell (MLC)
2.5"
SATA 6Gb/s
Temperature Monitoring and Logging, Enhanced Power Loss Data Protection, End-to-end data protection, 3D NAND Technology
66 g
5-year warranty
1.2 TB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
66 g
Performance
SSD Endurance
2455 TB
Internal Data Rate
450 MBps (read) / 380 MBps (write)
4KB Random Read
67500 IOPS
4KB Random Write
17500 IOPS
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
3.5 Watt (active) , 600 mW (idle)
Limited warranty - 5 years
70 °C
Shock Tolerance (operating)
1000 g @ 0.5 ms
Shock Tolerance (non-operating)
1000 g @ 0.5 ms
Vibration Tolerance (operating)
2.17 g @ 5-700 Hz
Vibration Tolerance (non-operating)
3.13 g @ 5-800 Hz
