This lamp is optimized to work with your InFocus projector, often resulting in higher brightness, longer life, and lower power usage.
- InFocus projector lamp
- Product Type
- Projector lamp
- Bulb life cycle
- 2500 hour(s) (standard mode) / 4000 hour(s) (economic mode)
- 15.2 cm x 15.2 cm x 15.2 cm
- 450 g
- Designed For
- InFocus IN3914, IN3916
- Product Type
- Projector lamp
- 15.2 cm - 15.2 cm - 15.2 cm
- 450 g
Lamp
- Life Cycle
- Designed For
