InFocus LiteShow 4 is a wireless adapter for any projector or display. Add it to any projector or other display with a VGA or HDMI input to quickly and easily share data, audio, and HD video over a secure wireless connection.
Fast and convenient wireless connection
LiteShow 4 displays seamless video and allows for easy connection and display from long range. On-board video decoding does the heavy lifting instead of the computer, so you'll get fast and clean reproductions of video and audio even at high resolutions and from older computers with less processing power. Visitors can connect to LiteShow 4 by inserting the LiteShow USB drive into their computer and start presenting -- no special admin. -
Flexible and secure
LiteShow 4 is flexible enough to be used for wireless display only or configured to fit into a complex and secure network infrastructure. LiteShow 4 maintains your security standards while giving multiple options for network and internet access. It also complies with many security protocols. -
Wireless presentation with access point
LiteShow 4 can work as a network access point, which allows any wireless-enabled computer or PDA to connect, present, and/or access corporate network resources or just the Internet. The Gatekeeper function can be set up to block all (display only), allow Internet access (display and get to the Internet) or allow all (display, Internet, and company network). -
Present through your network
There’s no need to switch wireless networks to present. Stay connected to your corporate network (email, shared folders, etc.) when you want to present – simply connect to LiteShow 4 like a printer and start presenting. Secondarily, when configured for network presentation, guests can still use the wireless/access point functions to present and access the Internet while keeping your network assets private. -
Control the display of multiple computers
The powerful Moderator feature allows a room full of computers to connect to a display and gives a “moderator” (via a web page) the ability to select which screen is displayed. Effortlessly switch presenters for seamless business collaboration. Teachers can wirelessly connect their students’ laptops and choose which student can display their work. QuadView can display up to four connected computers at the same time – ideal for web meetings, collaboration and classroom projects.
- InFocus LiteShow 4 - presentation server - Wi-Fi
- Presentation server
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Included Accessories
- 802.11n network adapter (USB 2.0)
- OS Required
- Microsoft Windows XP, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 or later, Android 4.0, Windows 8 (32/64 bits), Apple iOS 3.2 or later
- 14.986 cm x 9.652 cm x 2.794 cm
- 1-year warranty
- Designed For
- InFocus IN112, IN114, IN116, IN119, IN124, IN126, IN128, IN2124, IN2126, IN2128, IN3138; BigTouch INF5512, INF7012, INF8012, INF8511; JTouch INF5701, INF6500, INF6501, INF6502, INF6505, INF7002, INF8501; JTouch DigiEasel INF4030; JTouch Plus INF7530; JTouch with LightCast INF6501; ScreenPlay SP1080
- 14.986 cm
- 9.652 cm
- 2.794 cm
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Data Transfer Rate
- 150 Mbps
- Max Range Open Space
- 91.44 m
- MIMO technology
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2-PSK, WPA-Enterprise
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- 1 x VGA - HD-15 , 1 x HDMI output , 1 x 100Base-TX - RJ-45 , 1 x audio line-out - mini-jack , 3 x USB 2.0 - Type A
- C-Tick, NOM, FCC
- Power Device
- External power adapter
- OS Required
- Limited warranty - 1 year
- Designed For
- InFocus IN112a, IN112V, IN114a, IN114V, IN116a, IN116V, IN118HDa, IN118HDSTa, IN119HDx Business, IN122a, IN124a, IN124STA, IN124STx Short Throw Network, IN124x High Value Network, IN126a, IN126STA, IN126STx Short Throw Network, IN126x High Value Network, IN128HDSTx Short Throw Network, IN128HDx Professional Network, IN134UST, IN136UST, IN2114, IN2124, IN2124a, IN2124x Professional Network, IN2126a, IN2126x Professional Network, IN2128HDa, IN2128HDx Professional Network, IN3118HD, IN3124, IN3126, IN3128HD, IN3138HD, IN3138HDa Professional Network, IN3914, IN3924, IN3926, IN5110, IN5134, IN5135, IN5142, IN5144A, IN5145, IN5312, IN5542, IN5544, IN5554L, IN8601, IN8606HD , InFocus BigTouch INF5512AG, INF5711, INF5711AG, INF7011, INF7011AG, INF7012, INF8012, INF8511 , InFocus JTouch INF5701, INF5701p, INF6500E, INF6500EAG, INF6501c, INF6501cAG, INF6501w, INF6501wAG, INF6501wAGp, INF6501wp, INF6502WB, INF6502WBAG, INF6502WBAGP, INF6502WBp, INF6505, INF6505AG, INF6505E, INF6505EAG, INF7002e, INF7002WB, INF7002WBAG, INF8002, INF8501 , InFocus JTouch DigiEasel INF4030, INF4030p , InFocus JTouch Plus INF7530AG , InFocus JTouch with LightCast INF6501cAGp, INF6501cp , InFocus Learn Big IN3106, IN3108, IN5102, IN5104, IN5106 , InFocus LightPro IN1146 , InFocus Mondopad INF5720, INF5720AG, INF7021, INF7021AG , InFocus Play Big IN82 , InFocus ScreenPlay SP1080 , InFocus Work Big IN2102, IN2104, IN35, IN35W, IN36, IN37, IN38, IN5108
