Infocus Interactive Technology 2700 AN
Quicklinx: 7845WS00 Mfr#: IN3914
These short throw projectors with breakthrough LiteBoard interactive technology let teachers and other professionals interact with the projected image - turning any surface into an engaging, collaborative interactive workspace.
It's like an interactive whiteboard without the board.
  • Use wand as a mouse to draw, write and click
    Control all your favorite PC or Mac applications with the wireless LiteBoard Wand just as you would with your mouse.
  • Interact up close or away for maximum accessibility
    Anyone can participate and interact because they don't need to touch the image - just point and click the wand. You can't do that with an interactive whiteboard.
  • Room-filling audio
    Get your message across from the front row to the back with the IN3900 projector's clear and powerful audio system - one of the best you'll hear in this price range.
  • Minimal shadow interference
    Get big images when the IN3900 short throw projector is close to the wall to reduce shadows, free up space and reduce ambient noise.
  • Control the display of multiple PCs
    A presenter or teacher can connect up to 32 computers to one projector (via a network or optional wireless connection) and control who presents from one web page.
InFocus IN3914 - DLP projector - standard lens
DLP projector
Built-in Devices
Stereo speakers
Brightness
2700 lumens
Contrast Ratio
3200:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Lens
Standard lens
Bulb type
220 Watt
Bulb life cycle
Up to 2500 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video, component video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p, 1080/60p
Video Output
RGB
Speakers
Speaker(s) - integrated
238 Watt
3.2 cm x 25.2 cm x 12.7 cm
4.5 kg
DLP projector
Built-in Devices
Stereo speakers
Projector
Brightness
2700 lumens
Brightness (Reduced)
2200 lumens
Contrast Ratio
3200:1
Image Size
123 cm - 270 cm
Projection Distance
0.75 m - 1.65 m
Throw Ratio
0.61:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
220 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Korean
Eco-Mode technology, High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, LiteTouch, Short Throw Technology
Lens
Standard lens
Zoom Factor
1.35x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, composite video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
10 Watt
Speakers
2 x right / left channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B
LiteBoard Wand Kit, remote control
1 x VGA cable , 1 x USB cable
Security Features
UL, C-Tick, cUL, NOM, FCC
238 Watt
3.2 cm
25.2 cm
12.7 cm
4.5 kg
Limited warranty - parts and labour - 2 years , Limited warranty - replacement - lamp - 6 months , Limited warranty - accessories - 90 days
5 °C
Sound Emission
35 dB
