These short throw projectors with breakthrough LiteBoard interactive technology let teachers and other professionals interact with the projected image - turning any surface into an engaging, collaborative interactive workspace.
It's like an interactive whiteboard without the board.
Use wand as a mouse to draw, write and click
Control all your favorite PC or Mac applications with the wireless LiteBoard Wand just as you would with your mouse. -
Interact up close or away for maximum accessibility
Anyone can participate and interact because they don't need to touch the image - just point and click the wand. You can't do that with an interactive whiteboard. -
Room-filling audio
Get your message across from the front row to the back with the IN3900 projector's clear and powerful audio system - one of the best you'll hear in this price range. -
Minimal shadow interference
Get big images when the IN3900 short throw projector is close to the wall to reduce shadows, free up space and reduce ambient noise. -
Control the display of multiple PCs
A presenter or teacher can connect up to 32 computers to one projector (via a network or optional wireless connection) and control who presents from one web page.
- InFocus IN3914 - DLP projector - standard lens
- DLP projector
- Built-in Devices
- Stereo speakers
- Brightness
- 2700 lumens
- Contrast Ratio
- 3200:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Lens
- Standard lens
- Bulb type
- 220 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p, 1080/60p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 238 Watt
- 3.2 cm x 25.2 cm x 12.7 cm
- 4.5 kg
- 2-year warranty
- DLP projector
- Built-in Devices
- Stereo speakers
Projector
- Brightness
- 2700 lumens
- Brightness (Reduced)
- 2200 lumens
- Contrast Ratio
- 3200:1
- Image Size
- 123 cm - 270 cm
- Projection Distance
- 0.75 m - 1.65 m
- Throw Ratio
- 0.61:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Max Sync Rate (V x H)
- 85 Hz x 91.1 kHz
- Bulb type
- 220 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Korean
- Eco-Mode technology, High-bandwidth Digital Content Protection System (HDCP), BrilliantColor, LiteTouch, Short Throw Technology
Lens
- Standard lens
- Zoom Factor
- 1.35x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, composite video
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x audio line-in - RCA , 1 x microphone - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B
- Included Accessories
- LiteBoard Wand Kit, remote control
- Cables Included
- 1 x VGA cable , 1 x USB cable
- Security Features
- UL, C-Tick, cUL, NOM, FCC
- Voltage Required
- 238 Watt
- 3.2 cm
- 25.2 cm
- 12.7 cm
- 4.5 kg
- Limited warranty - parts and labour - 2 years , Limited warranty - replacement - lamp - 6 months , Limited warranty - accessories - 90 days
- 5 °C
- 40 °C
- Sound Emission
- 35 dB
