The InFocus IN8606HD provides CEDIA-level features and performance at a ground breaking entry-level price. The IN8606HD delivers the most significant home cinema product in a decade - redefining home cinema projection.
ISFccc and color management
The IN8606HD enables color calibration right out of the box to give you the most color accuracy and flexibility. -
Immersive 3D
Get the cinematic thrill of a 3D experience in the comfort of your home with the IN8606HD projector. -
Digital connectivity
The IN8606HD comes fully loaded with the latest and complete set of connections. -
UNISHAPE Lamp technology
UNISHAPE (UNIversal SHAPEd Lamp Light technology) shapes the light to provide the best possible image output for every millisecond of video. The light waveform shape is repeated in synchronization with the image processor and color wheel of the IN8606HD to achieve the very best possible image output.
- InFocus IN8606HD - DLP projector - standard lens - 3D - black
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Black
- Built-in Devices
- Stereo speakers
- Brightness
- 2500 ANSI lumens
- Contrast Ratio
- 10000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Lens
- Standard lens
- Bulb type
- 230 Watt
- Bulb life cycle
- Up to 4500 hours - normal mode , Up to 6000 hours - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-H)
- Video Modes
- 480p, 720p, 1080p, 480i
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 350 Watt
- 28.5 cm x 26.1 cm x 20.8 cm
- 3.15 kg
- 2-year warranty
- 3D Capable
- Built-in Devices
- Stereo speakers
- Enclosure Colour
- Black
Projector
- Brightness
- 2500 ANSI lumens
- Brightness (Reduced)
- 2000 ANSI lumens
- Contrast Ratio
- 10000:1
- Image Size
- 120 cm - 1000 cm
- Projection Distance
- 0.66 m - 8.25 m
- Throw Ratio
- 1.39 - 2.09:1
- Uniformity
- 95 %
- Resolution
- Full HD - Full HD (1920 x 1080) (native) / 1920 x 1280 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 90 kHz
- Bulb type
- 230 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Chinese (traditional), Chinese (simplified), English, German, French, Portuguese, Russian, Spanish
- Eco-Mode technology, 6-segment colour wheel, Closed Caption, 3D Digital comb filter, 16:9 aspect ratio support, 3D Color Management, UNISHAPE, ISFccc, 16:10 aspect ratio support, 4:3 aspect ratio support, Image Freeze Function, 5:4 aspect ratio support, blank screen, 3D Triple Flash technology, SRS WOW HD technology
Lens
- Standard lens
- Focus Type
- Manual
- Zoom Type
- Manual
- Zoom Factor
- 1.5x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-H
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x USB - mini-USB Type B (management) , 1 x USB - 4 pin USB Type A (power only) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 PIN DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x 3D Sync out
- Included Accessories
- Remote control
- Cables Included
- 1 x HDMI cable
- Security Features
- Security lock slot (cable lock sold separately), security bar
- UL, cUL, PSB, FCC, RoHS, CU-PCT
- Voltage Required
- 350 Watt
- Power Consumption Stand by
- 0.5 Watt
- 28.5 cm
- 26.1 cm
- 20.8 cm
- 3.15 kg
- Limited warranty - 2 years , Limited warranty - lamp - 1 year , Limited warranty - accessories - 90 days
- Sound Emission
- 33 dB
- Sound Emission (Economic Mode)
- 29 dB
