Infocus IN5108 4000 Ansi SXGA Projecto
Quicklinx: 69LWWS00 Mfr#: IN5108
  • High-Definition Multimedia Interface (HDMI)
The InFocus IN5108 is a premium digital projector that offers world class power and integration flexibility, with SXGA+ resolution. This projector is ideal for applications which require display of highly detailed information.
InFocus Work Big IN5108 - LCD projector - standard lens - black, silver
LCD projector
Black, silver
Built-in Devices
Stereo speakers
Brightness
4000 lumens
Contrast Ratio
1000:1
Resolution
SXGA+ (1400 x 1050)
Native Aspect Ratio
4:3
Colour Support
16.7 million colours
Lens
Standard lens
Lens Shift Direction
Horizontal, vertical
Bulb type
270 Watt
Bulb life cycle
Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
Digital Video Standard
Video Modes
480p, 720p, 1080i, 480i, 576i, 576p, 1080/60p
Video Output
RGB
Speakers
Speaker(s) - integrated
420 Watt
42 cm x 31.5 cm x 12.9 cm
7.12 kg
LCD projector
Built-in Devices
Stereo speakers
Enclosure Colour
Black, silver
Projector
Brightness
4000 lumens
Brightness (Reduced)
3200 lumens
Contrast Ratio
1000:1
Image Size
76 cm - 890 cm
Projection Distance
1.14 m - 13.34 m
Throw Ratio
1.5 - 1.8:1
Resolution
SXGA+ - SXGA+ (1400 x 1050) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Video Bandwidth
140 MHz
Colour Support
Max Sync Rate (V x H)
120 Hz x 91 kHz
Bulb type
270 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Korean
Eco-Mode technology, High-bandwidth Digital Content Protection System (HDCP), Wireless Ready
Lens
Standard lens
Focus Type
Manual
Lens Aperture
F/1.74-2.06
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical Keystone Correction
-40 / +40
Horizontal Keystone Correction
-20 / +20
Lens Shift Type
Manual
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
4 Watt
Speakers
1 x right / left channel
Input Device
External
Movement Detection Technology
Infrared
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video/audio input - RCA x 3 , 1 x component video / audio input - RCA x 5 , 1 x component video input - BNC x 5 , 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 (management) , 1 x USB (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x remote control - sub-mini phone 2.5 mm (management)
Remote control
1 x VGA cable , 1 x A/V cable
Security Features
UL, TUV GS, GOST, cUL, NOM, CCC, PSB, FCC, IRAM, RoHS
420 Watt
42 cm
31.5 cm
12.9 cm
7.12 kg
Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
10 °C
35 °C
Sound Emission
32 dB
30 dB
