The InFocus IN5108 is a premium digital projector that offers world class power and integration flexibility, with SXGA+ resolution. This projector is ideal for applications which require display of highly detailed information.
- InFocus Work Big IN5108 - LCD projector - standard lens - black, silver
- LCD projector
- Black, silver
- Built-in Devices
- Stereo speakers
- Brightness
- 4000 lumens
- Contrast Ratio
- 1000:1
- Resolution
- SXGA+ (1400 x 1050)
- Native Aspect Ratio
- 4:3
- Colour Support
- 16.7 million colours
- Lens
- Standard lens
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- 270 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p, 1080/60p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 420 Watt
- 42 cm x 31.5 cm x 12.9 cm
- 7.12 kg
- 2-year warranty
- LCD projector
- Built-in Devices
- Stereo speakers
- Enclosure Colour
- Black, silver
Projector
- Brightness
- 4000 lumens
- Brightness (Reduced)
- 3200 lumens
- Contrast Ratio
- 1000:1
- Image Size
- 76 cm - 890 cm
- Projection Distance
- 1.14 m - 13.34 m
- Throw Ratio
- 1.5 - 1.8:1
- Resolution
- SXGA+ - SXGA+ (1400 x 1050) (native) / 1600 x 1200 (resized)
- 4:3
- Video Bandwidth
- 140 MHz
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 91 kHz
- Bulb type
- 270 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Korean
- Eco-Mode technology, High-bandwidth Digital Content Protection System (HDCP), Wireless Ready
Lens
- Standard lens
- Focus Type
- Manual
- Lens Aperture
- F/1.74-2.06
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
- Keystone Correction Type
- Digital
- Keystone Correction Direction
- Vertical Keystone Correction
- -40 / +40
- Horizontal Keystone Correction
- -20 / +20
- Lens Shift Type
- Manual
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 4 Watt
- Speakers
- 1 x right / left channel
Input Device
- External
- Movement Detection Technology
- Infrared
- 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video/audio input - RCA x 3 , 1 x component video / audio input - RCA x 5 , 1 x component video input - BNC x 5 , 1 x HDMI input - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 (management) , 1 x USB (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x remote control - sub-mini phone 2.5 mm (management)
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable , 1 x A/V cable
- Security Features
- UL, TUV GS, GOST, cUL, NOM, CCC, PSB, FCC, IRAM, RoHS
- Voltage Required
- 420 Watt
- 42 cm
- 31.5 cm
- 12.9 cm
- 7.12 kg
- Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
- 10 °C
- 35 °C
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 30 dB
