Infocus IN3138HDa 1920x1080 4000 Lumens DLP 3D Projector
Quicklinx: BLL1WS00 Mfr#: IN3138HDA
Add a high-powered 1080p IN3138HDa network HD projector to your meeting room or classroom for a price that will fit your tight budget.
You'll get incredible image quality and smooth video playback through its two HDMI ports, including one with MHL compatibility. Easily manage the IN3138HDa over the network and easily install it with AMX and Crestron room control systems.
  • Digital connectivity
    Fully loaded with the latest set of connections.
  • Immersive 3D
    Enjoyable and comforatble 3D experience in the classroom or office.
  • Network support and control
    IT managers and tech teams can manage the IN3138HDa HD projector remotely.
InFocus IN3138HDa Professional Network - DLP projector - 3D
DLP projector - 1080p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
4500 lumens
Contrast Ratio
20000:1
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1 billion colours
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-H)
Video Modes
480p, 720p, 1080p, 480i
Speakers
Speaker(s) - integrated
340 Watt
28.5 cm x 26.1 cm x 12.18 cm
3.15 kg
3D Capable
Built-in Devices
Speaker
Ethernet
Projector
Microdisplay
DarkChip 3
Brightness
4500 lumens
Brightness (Reduced)
3200 lumens
Contrast Ratio
20000:1
Image Size
66 cm - 825 cm
Projection Distance
1.2 m - 10 m
Throw Ratio
1.39 - 2.09:1
Uniformity
80 %
Resolution
WXGA - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1 billion colours
Max Sync Rate (V x H)
120 Hz x 90 kHz
Bulb life cycle
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Portuguese, Russian, Spanish
6-segment colour wheel, BrilliantColor, DLP 3D Ready, 16:9 aspect ratio support, 16:10 aspect ratio support, 4:3 aspect ratio support, MHL compliance, 3D Triple Flash technology
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.5x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video, MHL
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x network - RJ-45 (management) , 1 x USB - 4 pin mini-USB Type B (management) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), security bar
UL, TUV GS, cUL, PSB, FCC, CU-PCT
Power Source
AC
340 Watt
Power Consumption Stand by
0.5 Watt
28.5 cm
26.1 cm
12.18 cm
3.15 kg
Limited warranty - 2 years , Limited warranty - lamp - 6 months , Limited warranty - accessories - 90 days
Sound Emission
37 dB
35 dB
